Hondata intake manifold gasket question
HI, i am in need of the hondata gasket or one like it soon, i have my motor out, and wnat to put it back in, but not until i put one on, well an-r is out of the gsr, and i dont want to pay for the hondata, cause i feel they are probably all the same, am i right, is the i found on ebay just as good or very similar asa hondatas, and also, it is the race version, well i need the version with the hole for fluid, do you think i can cut a hole in the gasket for it. thanks
im not sure if the quality is the same but you should be able to cut out the hole for the coolant to flow through without a problem. i was looking into the hondata one and you have to cut out the hole also.
patastinky
Dec 4, 2004 07:32 AM
