crx hf to si problem
Old Feb 8, 2004 | 07:14 PM
socalcrx1's Avatar
Default crx hf to si problem
i just swapped out my 91 crx hf motor to an si motor (non-vtec) and right away i started to experience problems. when i turn the key to the on position, the fuel injectors as well as the fuel filter start to spit fuel out like crazy! everything seems to be tight and put together properly. could it be bad o-rings? relays? im still using the stock pm8 ecu, but i dont know if that has anything to do with the problem. any ideas?!
Old Feb 9, 2004 | 06:29 AM
jlicrx's Avatar
Default Re: crx hf to si problem (socalcrx1)
which wiring harness do you have on the engine? if your car is HF, you MUST use the HF harness - the Si harness will not work
Old Feb 12, 2004 | 05:52 PM
socalcrx1's Avatar
Default Re: crx hf to si problem (jlicrx)
i'm using the hf harness
Old Feb 12, 2004 | 06:44 PM
Hybridize's Avatar
You should probably be using the PM6 ecu, but I doubt that has the slightest thing to do with the fuel leak.
Most definitely go back through the fuel rail and filter to replace the o-rings and gaskets. You might just want to get a new filter instead of searching for those washers. Any parts store should be able to get you o-rings for the injectors.
Old Feb 12, 2004 | 06:50 PM
Hybridize's Avatar
Just hit me.
The Hf and Si use different banjo bolts on the fuel lines. The Hfs have a single hole in them, while the Si's have a recessed ring carved into them. I'm not sure if there's a way to make one or the other work together, but it's definitely something you should be aware of and check out.
Old Feb 12, 2004 | 06:52 PM
ghettocrxsi's Avatar
Default Re: (Hybridize)
Also make sure that you have a copper washer on both sides of the banjo or it will not seal.
Old Feb 12, 2004 | 08:26 PM
JLockheed's Avatar
Default Re: (ghettocrxsi)
the first time i took my intake mani apart (i was getting ready to do the dx to si conversion, but a didnt show up) when i put it back together i had the same prob. Tightening up the banjo bolt fixed it. - if that helps out
Old Feb 12, 2004 | 08:46 PM
lightcrx's Avatar
you can use the si harness on a hf all you have to do is move the ignitor(white) wire to the other shock tower, im using a si on my hf, it took a while to figure it out tho
-joseph
Old Feb 13, 2004 | 06:16 AM
jlicrx's Avatar
Default Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">you can use the si harness on a hf all you have to do is move the ignitor(white) wire to the other shock tower, im using a si on my hf, it took a while to figure it out tho
-joseph</TD></TR></TABLE>
you cannot swap HF and Si harnesses - all of the wires are in different locations where the harness plugs into the chassis harness at the firewall on the driver's side - on the HF, the alternator wire goes through this connector which it doesn't on the Si
jdmekcoupe96
Jun 2, 2006 04:20 AM
JSPECHB
Jul 16, 2003 07:31 AM
Tbone
Jun 18, 2002 01:34 PM
Rob!
Apr 12, 2002 10:30 AM
jmalucci90crx
Mar 22, 2002 07:23 PM
