H22 Swap into an Integra with JDM front end??? Possible??
Old Feb 8, 2004 | 06:50 PM
ozzyman's Avatar
Default H22 Swap into an Integra with JDM front end??? Possible??
I currently have a H22 in my 2001 Integra and now I'm onto my next project. I've always loved the JDM fronts and I wasnt sure if the JDM radiator support moves up closer to the motor than the USDM one. My radiator fans BARELY misses the clutch bleeder valve. I was wondering if anyone has done this swap with this conversion before with no problems.
Old Feb 8, 2004 | 07:35 PM
ozzyman's Avatar
Default Re: H22 Swap into an Integra with JDM front end??? Possible?? (ozzyman)
Old Feb 8, 2004 | 08:26 PM
ozzyman's Avatar
Wheres all the HT hybrid guru's?
Old Feb 8, 2004 | 10:31 PM
ozzyman's Avatar
TTT
Old Feb 8, 2004 | 10:49 PM
JDMH22HATCH's Avatar
Are you running a slim fan? You can also contact C&R and order a radiator with front mount slim push fan. Either way you'll be fine. Just call and talk with Rob Cordona, he's a good guy. Good luck
Brandon
Old Feb 8, 2004 | 11:29 PM
ozzyman's Avatar
Default Re: H22 Swap into an Integra with JDM front end??? Possible?? (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">Are you running a slim fan? You can also contact C&R and order a radiator with front mount slim push fan. Either way you'll be fine. Just call and talk with Rob Cordona, he's a good guy. Good luck
Brandon</TD></TR></TABLE>
Thanks for the info man. Ill be sure to contact them.
Old Feb 9, 2004 | 05:06 AM
VTECVillain's Avatar
I've seen both NA and turbo'd H22 Integra's with a JDM front end. I can't speak from experience because I haven't owned or performed the swap. I do know that it will fit, just not sure what exactly is involved but it shouldn't be much different that having the stock US front. Using a slimline fan or possibly a radiator swap would be the only mods that could imagine.
Old Feb 23, 2004 | 09:55 AM
LOSERboy's Avatar
Default Re: H22 Swap into an Integra with JDM front end??? Possible?? (VTECVillain)
Yeah.....its possible...the h22 does not effect the front end of the car.......you'll just have to run a civic radiator because the location of the alternator on the h22 would hit the "condenser" if it was still retained.......
my friend had a h22 integra with a jdm front end and I LOVED THAT CAR........he ended up selling to a friend of ours in lousiana....
Old Feb 23, 2004 | 04:14 PM
somethinwikd's Avatar
Default Re: H22 Swap into an Integra with JDM front end??? Possible?? (LOSERboy)
loserboy is right about the civic radiator. even if you dont keep the condenser too close for my comfort level... my h22 ran a little hotter but noting that bothered me... not to mention the car made a 3700 mile move with me from sunny cali to tenn with no probleam other than the constanly empty fuel tank...
Old Feb 23, 2004 | 07:32 PM
Newman's Avatar
New User
The JDM ITR front end radiator support is relatively in the same spot, but is maybe an inch or so more forward so there's slightly more clearance. There is no difference or no problem when doing the conversion with a H22 swap.
Old Feb 23, 2004 | 07:35 PM
ozzyman's Avatar
Default Re: H22 Swap into an Integra with JDM front end??? Possible?? (Newman)
Awesome... thanks for all the info guys!!
Also Newman... my friend should be picking up my P28 H22 chip from you soon. He was the one inquiring about the SiR-G foglights.
Old Feb 23, 2004 | 07:38 PM
Newman's Avatar
New User
Damn... I thought he was going to come back when he said he would because I already got rid of all of the DC2 foglights, but I have the chip
Old Feb 23, 2004 | 10:03 PM
ozzyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">Damn... I thought he was going to come back when he said he would because I already got rid of all of the DC2 foglights, but I have the chip</TD></TR></TABLE>
Yeah he wanted the genuine ones or something. Didnt quiet understand. Anyways hes also going to pick up a conversion harness when he picks up my chip.
CivicSH
Aug 25, 2007 05:22 AM
j.dizzle
May 20, 2007 10:32 AM
ares650
Sep 22, 2004 10:22 AM
H22A1CivicEG
Apr 23, 2004 04:55 AM
chewiejdh
Jun 29, 2003 04:36 PM
