NEED ELECTRICAL HELP PLEEEEEASE!
Alright, this **** just has me straight up baffled:
I have a '94 gsr sedan, and recently my exterior lighting has been actin' a fool y0. Well, to begin with, i should tell you that my turn signals, emergency flashers have all been blinking like double-time or even triple-time since i got the car. Then one day i turn my headlights on and the dash indicator light for the right-hand turn signal stays on until i turn my headlights off. The FRONT-PASSENGER bulb doesn't turn on when I have my lights ON, but the bulb functions fine as a turn signal when i have my lights OFF. ALSO, as is now, my REAR-passenger side turn signal NEVER works, and I checked the bulb and it was fine. My front-passenger side turn signal works ONLY if my headlights/parking lights are OFF.
Seriously, this is one of the most bizzare issues i've ever had. Unless any of you knowledgeable folk have some good insight herr, I'm gonna have to bite the bullet on this one and spend the $ at the shop, since my turn signal ain't workin at night, and i'm not tryin to get pulled ova'.
-matt
-matt
the resistor for your blinkers maybe goin', that should be an easy fix. As for the headlights....I don't have a flippity fuggin' clue why that's happening. Lemme sleep on it.
It sounds like some of your lighting wire harness is shorted. I dunno, that is one odd problem. I would start start tracing wires, buy or borrow a multimeter and checking continuity throughout your wiring. It would really help if you had a wiring diagram too.HTH
Rick40
Mar 3, 2018 03:33 AM
pliskin8
Jul 7, 2011 06:30 PM
kr0n1c
Apr 15, 2011 03:34 PM
