Precision GT35E- GSR. completed build up (dyno numbers posted page 1)
b18c1
Darton t-sleeves (sleeved @ carboy)
STR block guard
CP 9:0:1 c/p
Eagle H-beams
skunk2 Intake manifold
InlinePRO turbo manifold (Arturbo
Precision GT35e .60AR (Arturbo
TiAL 38mm wastegate 1 bar spring (ben@importparts.com
Precision 880cc Injectors (ben@importparts.com
AEM FPR
AEM fuel rail
apexi avc-r b/c
apexi power fc
The piping was modifed from my old Greddy kit setup to accomadate the new turbo and manifold positioning.
history: blown block from greddy kit trying to push 300whp. I know alot of people can do 300whp stock block, but i couldn't.. end of story.
I'm in the process of breaking in the motor. after my 1.5k mile break-in, ill hit the dyno and POST numbers with a/f charts. Wish me luck. 400whp is my goal now.
Pictures:
dyno numbers
This is at 14psi. The tuner stopped due to ignition issues. (not enough spark)
Other than that, there is so much room for improvement! Looks like my goal isn't met, i'm kinda upset, but it does feel pretty quick i guess..
Modified by boostin GSR at 10:03 PM 2/25/2004
STR block guard
CP 9:0:1 c/p
Eagle H-beams
)Precision GT35e .60AR (Arturbo
)TiAL 38mm wastegate 1 bar spring (ben@importparts.com
)Precision 880cc Injectors (ben@importparts.com
)AEM FPR
AEM fuel rail
apexi avc-r b/c
apexi power fc
Pictures:
dyno numbers
Looking good man, always nice to see a clean turbo gsr. Good luck in trying to hit your goal which I'm sure you'll be able to do no prob.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon_2b_evil »</TD></TR><TR><TD CLASS="quote">what size piping is that?
what size is that off the turbo?</TD></TR></TABLE>
the piping is straight from the greddy kit, correct me if im wrong but i THINK it's 2'' from IM to intercooler and from the turbo it's 2.5''. (not 100% sure)
thanks for all the replys, i can't wait to hit the dyno once again.. i don't know what to expect, all i know is that my goals are aimed high!
400 or bust.
400 or bust.
yea my tuner suggested to add a block guard for insurance for sleeves, it actually looked pretty nice after they machined it down, all shiny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostin GSR »</TD></TR><TR><TD CLASS="quote">yea my tuner suggested to add a block guard for insurance for sleeves, it actually looked pretty nice after they machined it down, all shiny
u sure u got a darton sleeve?
</TD></TR></TABLE>u sure u got a darton sleeve?
the piping is straight from the greddy kit, correct me if im wrong but i THINK it's 2'' from IM to intercooler and from the turbo it's 2.5''. (not 100% sure)</TD></TR></TABLE>
Your wrong!
jk. You just had it backwards, 2" from the turbo to IC, and 2.5 from IC to IM. I'm sure your wondering why, since this seems backwards, my guess would be because 2" is the size of the piping comming off the turbo.
Also, I wouldn't think you'd need a block gaurd with those sleeves, I don't know a ton about either process, but I think you'd have more of a risk of ******* up your sleeves while installing the block gaurd, and those sleeves should be good to like 800whp or something crazy, right?
And what is that yellow stuff that you used to rig up your intake filter piping, I need to do something similar, i'd love to know what you used to do that. Nice setup btw. Good luck.
Your wrong!
jk. You just had it backwards, 2" from the turbo to IC, and 2.5 from IC to IM. I'm sure your wondering why, since this seems backwards, my guess would be because 2" is the size of the piping comming off the turbo.Also, I wouldn't think you'd need a block gaurd with those sleeves, I don't know a ton about either process, but I think you'd have more of a risk of ******* up your sleeves while installing the block gaurd, and those sleeves should be good to like 800whp or something crazy, right?
dang i guess it's time to search for a better filter.
i hope i can back up my setup with some nice numbers
in the mean time im going to baby my car to death!
