ITR turbo set-up Radiator????
Old Feb 8, 2004 | 06:08 PM
mstyper's Avatar
Default ITR turbo set-up Radiator????
I will be turboing my ITR in the next month or two I have been searching every post that I can find and I have came up with two solutions. The first one is go with Full Race Kit or go Custom
Custom Kit includes:
Here is a little list I put together:
* Turbo (I recommend Precision SC50...that's what I'm getting!)
* Turbo Exhaust Manifold (Inline Pro, Full-Race, Lovefab)
* Wastegate (TiAL 38mm)
* Blowoff valve (HKS SSQV, Tial, Blitz DD)
* Intercooler (Precision, Spearco, PWR)
* Intercooler piping (InlinePro, REVHard)
* Downpipe (3" Custom)
* Vacuum lines
* Hoses
* Clamps
* Tee's
* Oil feed line (Flamenco-T on HT)
* Oil return line (Flamenco-T on HT)
* Vacuum manifold (You can get one from McMasterCarr)
* Bigger Injectors (Precision 525cc or RC550cc)
* Fuel Management (Hondata s200b)
* OBD-II to OBD-I conversion harness
* Fuel pump (Walbro 255lph hp)
* Oil Catch can (not needed, but recommended)
* NGK spark plugs (NGK7E)
<U>The only thing that I have not found an answer to is do I need to change my radiator?????</U>
I will be keeping my AC and power steering.
Reason for keeping AC is it gets hotter then Hell in the summer time. and with the HONDATA it will turn the AC off when it gets to a certain throttle point.
Old Feb 8, 2004 | 06:12 PM
nekkedR's Avatar
Default Re: ITR turbo set-up Radiator???? (mstyper)
i still have my stock one,i have no problems with over heating, i run a 50/50 mixture and 1 container of reline water wetter. i just had to put a flex-alite fan on the other side for clearance with the turbo. if your gonna run a/c you'll probably need two fans
Old Feb 8, 2004 | 06:13 PM
Irishweird00's Avatar
Banned
You might want to.... overheating can be a problem, and without a good radiator it could cause you a problem as well.....
you don't have to though. they are cheap... 300 or so.
Old Feb 8, 2004 | 07:03 PM
Ls-Rturbo's Avatar
300 is a grip why dont u just get the stock automatic radiader it is dual core to help cool the tranny
Old Feb 8, 2004 | 07:11 PM
vtec.dc2's Avatar
i run stock one.. you should be fine for daily driving. i did have to replace passenger radiator fan for clearance.
Old Feb 8, 2004 | 07:12 PM
FOrSfEd's Avatar
Default Re: ITR turbo set-up Radiator???? (bl18t)
Stock radiator will be fine up too around mid 400. I did a custom kit as well but if I could go back i would prob do a Full race kit.
Old Feb 8, 2004 | 09:21 PM
95LSDOHC's Avatar
Default Re: ITR turbo set-up Radiator???? (FOrSfEd)
depending on the manifold you choose, you might have no choice b/c of the lack of room, so if you pick lovefab or fullrace, u'll have to pick up a civic one so u can fit the manifold
Old Feb 9, 2004 | 04:16 PM
mstyper's Avatar
Default Re: ITR turbo set-up Radiator???? (95LSDOHC)
thanks for the info.
any other thoughts?
Old Feb 9, 2004 | 05:09 PM
Bnjmn's Avatar
Get a Lovefab sidewinder and keep your stock radiator.
Ben
Old Feb 9, 2004 | 06:05 PM
mstyper's Avatar
Default Re: ITR turbo set-up Radiator???? (Bnjmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">Get a Lovefab sidewinder and keep your stock radiator.
Ben</TD></TR></TABLE>
I was looking at that one but was unsure if I could keep my stock radiator or have to get a Civic one. If I do go with the Lovefab will I still be able to keep my AC?
Thanks for the help!!
Old Feb 9, 2004 | 07:39 PM
TravSi's Avatar
With that sidewinder you would be able to keep all that fun stuff......
Old Feb 10, 2004 | 03:03 AM
mstyper's Avatar
Default Re: ITR turbo set-up Radiator???? (TravSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravSi &raquo;</TD></TR><TR><TD CLASS="quote">With that sidewinder you would be able to keep all that fun stuff......</TD></TR></TABLE>
Thanks.... That was the answer I was looking for. Looks like I am getting the sidewinder. are there any more other parts on the rest of the kit that I have put together these lats two months by looking all over HT for information on custom set ups that any of you would change.
Old Feb 10, 2004 | 03:14 AM
PM-Performance's Avatar
i kept my stock radiator for a while, i only swapped it out cuz it got messed up from this F'ed up dump tube i had for a little.
Old Feb 10, 2004 | 06:32 AM
mstyper's Avatar
Default Re: ITR turbo set-up Radiator???? (itr206)
Thanks for all of the help that every one is giving me if any one has any other information that I might need on making the direction the turbo set for my ITR please let me know. All of the information is listed above so if you see something that I might need to change let me know.
THANKS ALL
Old Feb 11, 2004 | 01:17 PM
mstyper's Avatar
bump
Old Feb 11, 2004 | 06:39 PM
vtec.dc2's Avatar
if you daily drive, get inline pro, it won't fall apart and great quality log style manifold.
Old Feb 11, 2004 | 07:15 PM
scooter's Avatar
I have the sindwinder on my ITR. Unless he has changed the design you will not be able to get 2 fans in there. The turbo nearly touches the radiator. You will have to mount a pusher fan somehow if you want 2 fans. I am just using one fan and a Fluidyne radiator.
Also you will have to wrap the header or make a heat shield for it cause it puts off so much heat that you will over heat and bake off the paint on the hood.
some things to consider....
scott
Old Feb 11, 2004 | 07:25 PM
vtec.dc2's Avatar
Default Re: ITR turbo set-up Radiator???? (scooter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scooter &raquo;</TD></TR><TR><TD CLASS="quote">
scott</TD></TR></TABLE>
is this for any header or just the one you're talking about? i'd rather not bake paint off my hood.
Old Feb 12, 2004 | 12:27 PM
mstyper's Avatar
Default Re: ITR turbo set-up Radiator???? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">if you daily drive, get inline pro, it won't fall apart and great quality log style manifold.</TD></TR></TABLE>
Thanks for the information on the inline pro. But will I able to keep my AC?? Or is this a question that I should call Inline Pro about?
mstyper's Avatar
is this for any header or just the one you're talking about? i'd rather not bake paint off my hood.</TD></TR></TABLE>
Old Feb 12, 2004 | 01:38 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstyper &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for the information on the inline pro. But will I able to keep my AC?? Or is this a question that I should call Inline Pro about?</TD></TR></TABLE>
you should be able to keep a/c and power steering with inline pro manifold
Old Feb 12, 2004 | 05:23 PM
mstyper's Avatar
Thanks for that information that is what I have been looking for............
Rob!
Northeast (Sales)
22
Sep 5, 2007 07:37 PM
99whitegsr
Feb 28, 2005 06:28 PM
OG SHG_EM1
Mar 28, 2004 09:10 PM
OEMJDM
Jan 21, 2003 03:37 PM
pub
Dec 2, 2002 07:13 PM
