FIRST time at track UPDATE!! 2.3 60ft..im an idiot!
Old Feb 8, 2004 | 05:14 PM
tyflip2's Avatar
Default FIRST time at track UPDATE!! 2.3 60ft..im an idiot!
just got back from the track again with a 2.309 60 ft. and ran a 14.74
60........2.38
1/8.......9.682
1/4.......14.89
mph.....93.36
UPDATE: I AM AN IDIOT AT READ THE REACTION TIME. I DIDNT EVEN REALIZE THAT I WROTE THAT AND I WAS KINDA WONDERING WHY I WAS GETTING HARASSED SO MUCH FOR WHAT I THOUGH I PUT DOWN. I DID A 2.3 60 FT TIME. I FEEL LIKE AN IDIOT
setup was a 96 ek hatch with a jdm gsr swap with just intake. i think i could get it down to a 14.6 or so with a better launch. only got 3 runs in all day so i hope for better next time. tell me what you think. thanks for any help
Modified by tyflip2 at 1:54 AM 2/16/2004
Old Feb 8, 2004 | 05:17 PM
Fuster_Cluck's Avatar
Default Re: FIRST time at track UPDATE!! 2.3 60ft..im an idiot! (tyflip2)
I have a USDM GSR in my Eg hatch and pull 2.3 - 2.4 60' w/ 9.3 1/8th times....
Never ran the 1/4, but your times sound pretty good as far as the 60 / 1/8th
Old Feb 8, 2004 | 07:18 PM
95VXB16A's Avatar
not bad son, thats same time I run in the 1/4 also, but with a B16ASIR2 in my vx hatch.
Old Feb 8, 2004 | 07:35 PM
Team 4R's Avatar
i hope you dont mind if i swerve on your topic........ i've got a jdm gsr in my coupe and it just does not pull past 7k rpms..... you have any problems like that? some folks said my fuel pump may be too weak (it's the stock sohc part)..... which pump are you using?
Old Feb 8, 2004 | 08:52 PM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyflip2 &raquo;</TD></TR><TR><TD CLASS="quote">60........2.38</TD></TR></TABLE>
you 60ft time is the same as mine
differnce is, i have quaife LSD but in a 00 civic si..
what tires you got? what psi were they at? what did you launch at?
Old Feb 8, 2004 | 09:49 PM
tyflip2's Avatar
Default Re: FIRST time at track UPDATE!! 2.3 60ft..im an idiot! (SeanJohn1802)
i was running falken azenis at 23 psi. on that launch i was at 3000 rpm and just kinda feathered the clutch so that i didnt have very much wheel hop. seemed to work out alright.
as for team 4r: i am using the stock cx fuel pump also but it feels like my car pulls pretty hard up top. basically from 6-redline it is pulling pretty strong. i hope you can figure out your problem
Old Feb 8, 2004 | 10:10 PM
chads's Avatar
good job
Old Feb 8, 2004 | 11:06 PM
spoolineh2's Avatar
Default Re: FIRST time at track UPDATE!! 2.3 60ft..im an idiot! (OOsi)
not bad I was kind of worried when I saw the 3.xx earlier.
Old Feb 9, 2004 | 08:22 AM
tyflip2's Avatar
Default Re: FIRST time at track UPDATE!! 2.3 60ft..im an idiot! (ill94hatch)
yeah it completely slipped my mind that i was writing down my r/t and insisted that it was correct.
Old Feb 9, 2004 | 08:25 AM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OOsi &raquo;</TD></TR><TR><TD CLASS="quote">
what else you have done, and what are you running 1/4?</TD></TR></TABLE>
sorry flip, dont mean to thread jack...
but Quaife LSD, Exedy 9lb Flywheel, Exedy organic clutch, greddy evo... ran a 15.2
rims/tires, stock Si rims on kumho 712's at 30psi
i had at least 2-3 launchs with mad wheel hop
Old Feb 9, 2004 | 08:42 AM
tyflip2's Avatar
yeah wheels hop for me was reallly bad when i was dumping the clutch. the track was pretty sticky so the tires just hopped. so thats when on my last run i feathered it and it hopped a little but helped alot. i am gonna try to feather from 4000 next time and see if i can lower to a 2.2 60ft
Old Feb 9, 2004 | 05:32 PM
tyflip2's Avatar
bump for more opinions
Old Feb 9, 2004 | 05:44 PM
goforbroke's Avatar
MEAT PATTY
Well you did better then me my first time at the track I could only manage 2.5's all day long. I had the same track trap speed as you but I could only manage a 15.1 @93mph. I have a first gen b16a though.
Old Feb 9, 2004 | 05:52 PM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyflip2 &raquo;</TD></TR><TR><TD CLASS="quote">bump for more opinions</TD></TR></TABLE>
do you have all stock interior?? if so man, 14.9 is a damn good time
Old Feb 9, 2004 | 05:54 PM
Racerage1's Avatar
looks good man, i was able to pull 2.3 60ft on crappy street tires@20psi. what track did u go to?
Old Feb 9, 2004 | 05:55 PM
tyflip2's Avatar
i didnt have the spare tire or jack and i still have AC. i also removed the rear seat but im not sure i will do that again. it was a little more work than i though and it doesnt even way that much
Old Feb 10, 2004 | 12:28 PM
tyflip2's Avatar
i went to famoso raceway. it was the first time they opened this season so it was really crowded. next time i am hoping to get near a 14.5 or so. do you guys think i can do this with a better 60ft even with 93 mph traps? how much would a nice header help?
Old Feb 10, 2004 | 12:31 PM
Jimmy's Avatar
Global Moderator
Caps lock is your friend
Good times
Old Feb 10, 2004 | 12:41 PM
tyflip2's Avatar
Default Re: (USDMDC2)
haha i used capslocks because i originally made another post saying that my 69ft time was a 3.6 not knowing i put that and everyone was like wtf and asking me why it was so high. and i was htinking i put 2.3 and insisted it was right. so anyways i had to clear that up becasue i looked like a moron
Old Feb 10, 2004 | 02:53 PM
Declectic's Avatar
Default Re: (tyflip2)
i think you'll need some slicks to break that 60ft time you currently have .. thats a pretty good 60ft already, it maybe possible to run a 2.2 . . .
Old Feb 10, 2004 | 03:01 PM
JDM-97CX's Avatar
Default Re: (SeanJohn1802)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">i think you'll need some slicks to break that 60ft time you currently have .. thats a pretty good 60ft already, it maybe possible to run a 2.2 . . . </TD></TR></TABLE>
No he won't need slicks to break that 60'. He just needs to learn how to launch better and slip the clutch so he has no wheel hop at all. When I went to the track with my stock 97cx hatch I was able to pull a 2.3 60' and i gauranteee it would have been much better had i had a swap. I would not doubt that he could hit 2.0 or even a 1.9 without slicks, all a matter of knowin how to launch your car.
Old Feb 10, 2004 | 03:07 PM
tyflip2's Avatar
Default Re: (JDM-97CX)
yeah on the last run of a shitty day i just slipped it from 3 because i was having problems all day with wheel hop and tire spin so i just did it conservatively to make sure i get a halfway decent launch to get a 14. next time im going to try to slip from 4000 and i think that will help alot
Old Feb 10, 2004 | 03:14 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyflip2 &raquo;</TD></TR><TR><TD CLASS="quote">yeah on the last run of a shitty day i just slipped it from 3 because i was having problems all day with wheel hop and tire spin so i just did it conservatively to make sure i get a halfway decent launch to get a 14. next time im going to try to slip from 4000 and i think that will help alot</TD></TR></TABLE>
I slipped my cx from 4500.
Talk to stealth-95gsr (pretty sure that is his name..if not its close) he used to have a gsr with intake suspension and exhaust he ran a 14.5. I don't remeber what he slipped it from but it was pretty high up there.
Old Feb 10, 2004 | 07:33 PM
tyflip2's Avatar
thanks for the help!
Old Feb 11, 2004 | 06:49 AM
saleensolution's Avatar
i agree tires make the difference i could only pull 2.0 out of mine no matter how hard i try
