Budget rebuild
Old Feb 8, 2004 | 03:43 PM
D's Avatar
D
Default Budget rebuild
If anyone cares, pics of my current budget rebuild are up on our site..
i suppose 'budget' is a relative term. I'll post some general $ numbers when i get a chance to list everything out.
D
PS - this is why the Mini project is on hold.
Old Feb 8, 2004 | 03:44 PM
BlueR's Avatar
Default Re: Budget rebuild (D)
redo your link
Old Feb 8, 2004 | 03:47 PM
D's Avatar
D
Default Re: Budget rebuild (BlueR)
should work now.
Old Feb 8, 2004 | 03:59 PM
ZygSpeed's Avatar
Looks nice, good luck with the install/transplant.
Old Feb 8, 2004 | 04:34 PM
Dr Pooface's Avatar
Default Re: Budget rebuild (zygspeed)
Looks like fun. Whats up with the green paint on the pan?
Old Feb 8, 2004 | 06:42 PM
mstewar's Avatar
this to fix the stranded R, I assume(by you saying why the mini is on hold)..?
looks like it's coming together nicely.. i'm very curious as to what cost you've incurred..
Old Feb 8, 2004 | 07:09 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Budget rebuild (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">this to fix the stranded R, I assume(by you saying why the mini is on hold)..?
looks like it's coming together nicely.. i'm very curious as to what cost you've incurred..</TD></TR></TABLE>
yes, this is to fix his R. The budget numbers are so funny. D is so cheap. But the **** looks nice in person.
Old Feb 8, 2004 | 07:17 PM
D's Avatar
D
Default Re: Budget rebuild (RealTypeR)
eh.. a quick estimate from my head. probably missed something somewhere.
Parts:
Topline ITR .25OS slugs/rings - $180
Bearings - $100
Main/Head Studs - $180
GSR Rods (2 Free - Thanks Bert-O!)
Oil Pump - 80
Water Pump - 60? (cant remember)
Rear main seal - 13
Valve Seals - 11
Head gasket - 50
Oil pan gasket - 19
Upper Gasket kit - 36
Misc OEM bolts/nuts - 10
Tensioner/Timing belt - 90ish
Rod bolts - 35
parts ~800ish
Machine work:
Crank grinding - $75
Block Hone/Rod Resizing - $150
Piston Pin-fitting - my time
Port work - my time and $50 worth of carbide burs/sandrolls
Head Surfacing - my time
labor ~300ish
D
Old Feb 8, 2004 | 10:09 PM
Bbasso's Avatar
Looks like your doing it right
But what is up with the green?
Old Feb 9, 2004 | 05:19 AM
D's Avatar
D
Default Re: Budget rebuild (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">But what is up with the green?</TD></TR></TABLE>
i don't know what you're talking about.
Old Feb 9, 2004 | 05:22 AM
mstewar's Avatar
wow.. not bad at all!
Old Feb 9, 2004 | 06:09 AM
B18CXr's Avatar
green is hot
bling is not
Old Feb 9, 2004 | 07:08 AM
Johnny Tran's Avatar
Default Re: Budget rebuild (B18CXr)
thats no Pontiac 400ci block
fuggin hondas...
Zumo
Honda Civic (2006 - 2015)
21
May 14, 2006 06:48 AM
MSchu
Honda Motorcycles
39
Sep 16, 2005 05:25 PM
.RJ
Mar 29, 2004 09:55 AM
JohnW
Mar 3, 2004 06:05 AM
BakedCookies
Dec 17, 2003 11:19 AM
