P1298 Electric Load Detector (ELD) Circuit High Voltage
Old Feb 8, 2004 | 02:41 PM
cegleitz's Avatar
Default P1298 Electric Load Detector (ELD) Circuit High Voltage
how do i fix that code?
thanks.
Old Feb 8, 2004 | 03:43 PM
TeamNextGenChris's Avatar
Default Re: P1298 Electric Load Detector (ELD) Circuit High Voltage (cegleitz)
does that mean the ELD is receiving a high input voltage,or that there's a problem with the ELD itself?
best thing i can say is get a shop manual and do the troubleshooting procedure for the ELD.maybe also check out how much voltage your alternator is putting out.
chris
Old Feb 8, 2004 | 04:31 PM
cegleitz's Avatar
allright, appreciate the help. thanks.
Old Feb 9, 2004 | 04:36 AM
EE_Chris's Avatar
Default Re: (cegleitz)
Anything relating to "voltage" means you need a multi-meter in order to see just what that voltage is.
In order to troubleshoot the problem, you need some schematic/wiring information, as well the diagnostic procedure to do so.
The repair information can be found in a Helms manual (located in my sig). For a multi-meter, look into a Fluke or something similar.
Aside from this, you can visually check your wiring for cracks and the like, but you need the above "tools" to do anything with any suggestions anyone could give you.
accord99power
Jun 12, 2008 10:49 AM
hazard2o9
May 12, 2008 12:10 PM
91civicEX
Jul 8, 2003 08:27 PM
