crx tech help!
I have a 90 crx si, with the stock D16 sohc motor lately the check engine light will come on, but not always, I feel a little bit of a power loss, when it comes on but not much, when i inspected the motor, i found that there was some oil on the plug wires right down next to the plugs, I know this isn't good. But what can I do??? plz help!?!?
Use the faq section in this forum and learn how to pull the codes from the ecu.
Then come back here and give us the code. There's no way we can tell whats wrong with your car when we don't know what code it's throwing.
yea, pull down ur rug on the passenger side, n' look at the ECU. Count how many times it blinks (example: it'll blink x times...then hesitates...then starts blinking again. Depending if you have more than one problem, then the ECU will blink x amount of times again) and post it here. Or read the FAQ n' it'll tell u how to do it.
