axle nut removal
Old Feb 8, 2004 | 12:59 PM
xSCTYGx's Avatar
Default axle nut removal
whatup guys...tryin to get my axle nut off on both sides and neither will budge...my motor is shot and im takin it out to drop a new one in, so its not like i can just go to a mechanics shop and get them to do it...ive already broken a 1/2 breaker bar, soaked them in pb blaster, torched it for bout 10 min, and used an air gun that has about 120 psi...the lil bastard wont even budge, im out of ideas!
Old Feb 8, 2004 | 01:02 PM
Sukebei Oni's Avatar
Default Re: axle nut removal (2Gen91Teg)
either get a bigger breaker bar with a pipe extension, or a bigger impact gun.
or you could always cut it off.
Old Feb 8, 2004 | 01:16 PM
not so JDM Dan's Avatar
Default Re: axle nut removal (Sukebei Oni)
all i have to say is 1/2 inch impact and a lot of wd-40
keep workin with it will go
Old Feb 8, 2004 | 01:32 PM
Padronis's Avatar
Default Re: axle nut removal (JDMDan)
I say keep working at it with the impact gun. I did that on my crank pulley until it finally gave.
Old Feb 8, 2004 | 01:33 PM
garados's Avatar
bigger breaker bar with a pipe, and it'll come off ... hopefully I used a 1/2" breaker bar with a 6 foot pipe and i had problems getting it off, and it wasn't even rusted on. I had them off just about 8 months ago, then tried to take them off 2 months ago. Good luck
Old Feb 8, 2004 | 01:34 PM
8o8da9speed's Avatar
Default Re: axle nut removal (garados)
hehe did u take off the cotter pin?
Old Feb 8, 2004 | 01:38 PM
Dan GSR's Avatar
Default Re: axle nut removal (8o8da9speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8o8da9speed &raquo;</TD></TR><TR><TD CLASS="quote">hehe did u take off the cotter pin? </TD></TR></TABLE>
wtf u talking about?
Old Feb 8, 2004 | 01:45 PM
Default Re: axle nut removal (Dan GSR)
i do not know...i am dead drunk
Old Feb 8, 2004 | 01:58 PM
kablamo's Avatar
get a can of penetrating lube (haha...anyways) and spray it on, let it sit half an hour, spray more, let it sit, spray more.
then get a bit breaker bar or find a new best friend with good air tools. hell if they are on that tight odds are other nuts are gonna be hard to remove too - only it will be harder to get a breaker bar on them.
Old Feb 8, 2004 | 02:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDan &raquo;</TD></TR><TR><TD CLASS="quote">all i have to say is 1/2 inch impact and a lot of wd-40
keep workin with it will go</TD></TR></TABLE>
nah, get a 3/4 inch impact gun 1200 ft/lb. I'll be getting one soon. Crank bolts don't stand a chance anymore.
Old Feb 8, 2004 | 03:23 PM
Dyno Queen's Avatar
haha thats why i need, yea get that bastard over where u can jump down on it and use your weight, ive had some good times with axle nuts as well, but u should be able to use your weight with a big *** pipe!
Old Feb 8, 2004 | 04:48 PM
xSCTYGx's Avatar
Default Re: axle nut removal (Dyno Queen)
well tonight, we broke another breaker bar, used up a whole can of wd-40 and pb blaster, broke a large socket wrench, and bent a 10 ft pipe extension we had laying around...tomorrow some dude is bringing over a larger air gun, we just dont know if itll work considering his compressor sucks...but if that doesnt work, is there any other way to take a motor out without taking the tranny out?? my friend suggested putting a jack stand under the tranny and hooking the engine lift up, then slowly taking everything up so that it creates an angle so the engine could just slide out? iunno im gettin pissed off at the thing..i may just go buy a 3/4 rachet and see if thatll work, iuno im runnin out of ideas lol!
Old Feb 8, 2004 | 04:59 PM
cccccccc's Avatar
ok the part thats the problem is where the nut is crushed in
on one of my axels we just cut that little part of the nut off
then it came off real easy
pm me if you need more help
Old Feb 8, 2004 | 05:06 PM
InfamousGSR's Avatar
Default Re: axle nut removal (c13r)
Im looking into buying a air gun. Whats a good one to get that has enough torque? I was looking at one that is 1000 ft lbs for 230$. I rather spend less though if I can get a different one.
Old Feb 8, 2004 | 05:14 PM
xSCTYGx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c13r &raquo;</TD></TR><TR><TD CLASS="quote">ok the part thats the problem is where the nut is crushed in
pm me if you need more help</TD></TR></TABLE>
hey man we already straightened that peice so thats not a factor..
Old Feb 8, 2004 | 06:37 PM
PlastikOwl
Guest
Posts: n/a
I snapped a socket in two pieces trying to do that once... took it back to sears and got a new one free of charge I only buy pittsburgh or snap-on now.
see if you can just cut the bolt off? Seems like it'd work.
Old Feb 8, 2004 | 07:46 PM
yellow_jacket's Avatar
Default Re: axle nut removal (PlastikOwl)
I have had this problem before. My impact gun puts out about 650 ft.lbs. I broke several breaker bars. I finally cut the nut with a ziz wheel. The parts I couldn't cut all the way I broke with a chisel and a hand sledge.
Old Feb 8, 2004 | 08:47 PM
you might want this one. its a pretty good brand.
http://www.harborfreight.com/c...=4312
Old Feb 8, 2004 | 09:08 PM
LeftCorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Gen91Teg &raquo;</TD></TR><TR><TD CLASS="quote"> is there any other way to take a motor out without taking the tranny out?? my friend suggested putting a jack stand under the tranny and hooking the engine lift up, then slowly taking everything up so that it creates an angle so the engine could just slide out?</TD></TR></TABLE>It's not absolutely necessary to remove the axle from the hub. Just seperate the knuckle from the lower control arm and swing the knuckle out and remove the axle from the trans. (or intermediate shaft) and let the half-shaft hang down.
Old Feb 8, 2004 | 10:06 PM
boosted_dc2's Avatar
Default Re: axle nut removal (LeftCorner)
all i know is i worked on mine for 2 nights only to get it off but now the fuking shaft is stuck in the hub. i said **** it and cut the boot and broke that ****** and the cv to get my motor out. but i am geting gators so i dont care.
the way i got it of as i ltterally heated it for 35 minutes straight then jumped on a breaker bar with a 4 foot pipe. heat it till its red hot
Landon
Old Feb 9, 2004 | 02:58 AM
NXSpoon's Avatar
Default Re: axle nut removal (boosted_dc2)
Had the same thing happen yesterday doing a GSR swap into an EJ.
What worked for us:
Can of lube
20 MINUTES with a Bernzomatic torch
1 heavy guy (that's me @195lbs.)
1/2in, breaker bar about 3 feet long.
Friend holding the socket over the nut w/ me jumping on bar.
Victory was finally achieved after we REALLY heated that nut up.
Old Feb 9, 2004 | 06:50 AM
Default Re: axle nut removal (NXSpoon)
Thats the gun I was checking out in a magazine my cousin had. Seems good.
Old Feb 9, 2004 | 07:01 AM
Full Race EG's Avatar
Default Re: axle nut removal (InfamousGSR)
i have snaped a very long half inch snap on breaker bar and a snap on socket trying to get mine off. i finally got this:
1' breaker bar. weight about 20 pounds (ATLEAST). havent broke it yet.
no more axle nut problems.
Old Feb 9, 2004 | 07:40 AM
tilt's Avatar
if you dont care what happens to the axle u could prob dremel the nut off
Old Feb 9, 2004 | 07:50 AM
Arsenal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">all i know is i worked on mine for 2 nights only to get it off but now the fuking shaft is stuck in the hub. i said **** it and cut the boot and broke that ****** and the cv to get my motor out. but i am geting gators so i dont care.
Landon</TD></TR></TABLE>
had the same problem, seperate the knuckle and take it to a shop and have the shaft pressed out, only $10.
Its only 3 bolts, all 17mm I think, Tie rod, upper control arm joint? And lower ball joint.
