Has this ever happen to anyone/HELP
Old Feb 8, 2004 | 12:28 PM
Type R106's Avatar
New User
Default Has this ever happen to anyone/HELP
when I turn on the right turn signal, my taillight flashes along with the turn signal. when i step on the brakes, both lights stop flashing, and when I releases the brakes, it flashes again, both of them. A little trick that seems to fix the problem was to turn on the signal, remove the tail light for a few seconds, and plugging it back in. This work probably for about a while, but then it would not work again.
a little extra background. Eversince I did the fog without headlight trick, when I turn on my remote starter, the lights does not flash anymore, but everything else seems to work fine. no blown fuses or anything. Not sure if the 2 problems are related, since the brake light thing happen way after the remote starter issue. sorry about the lengthy explanation, and any help would be apreciated. thanks
Old Feb 8, 2004 | 01:47 PM
2muchPSI's Avatar
Default Re: Has this ever happen to anyone/HELP (Type R106)
LOL
check your wiring
baseballbirch
Honda CR-V & Element
Aug 24, 2015 09:08 AM
tantrumcrx
May 12, 2010 08:19 PM
ruah_23
Nov 21, 2004 07:29 PM
