Please Help (Brake noice maybe?)
Old Feb 8, 2004 | 11:24 AM
russianroulette's Avatar
Default Please Help (Brake noice maybe?)
Hey guys,
Wondering if anyone has experienced this before.
I am getting this VERY VERY loud squealing/grinding noise from
my brakes (can't figure out from the front or back), but the noise is
extremely loud. It almost sounds like there is a rock stuck in between the
pad and the disk. Last time this noise happened was over a month ago, but
after driving for a couple of minutes, it went away. This time, It will not go
away and is constantly squealing even when you are not on the brake pedal.
At very low speeds you can actually hear the squeal rotation. (Squeal,---squeal---squeal) as it goes around 360degrees. Has anybody experienced this before?
I can't seem to figure out what the hell it could be since the car still brakes fine,
and last time the noise only lasted about 5 minutes of driving???
Any help would be greatly appreciated.
Thanks,
Will
Old Feb 8, 2004 | 11:28 AM
conesmasher's Avatar
Default Re: Please Help (toymx6)
sounds like you need new pads..........if not that a pad could be broken
Check out the surface on your brakes, and most of all take wheels off and inspect pads, for this is the only real way to check out your brakes.
Old Feb 8, 2004 | 07:51 PM
Default Re: Please Help (Cone Smasher)
it was a stuck caliper grinding.
Thanks for your reply!
cheers,
Will
GAngulo7
Honda Civic (2001 - 2005)
Jan 26, 2010 08:17 PM
lv6l
Jan 4, 2005 11:42 AM
