Removing 5th Gen Bumper
What the hell is going on. I know what I have to remove. The problem I am having is with these plastic clips that line the top of the bumper (where it meets the trunk lining).
Heres an example pic:
I have tried to unscrew them and all they do is spin freely inside the plastic washer. I have tried to pry them up but they are so pliable that they just bend in half. I dont want to saw these lil ******* off. Whats going on here?
What I used was a pair of dykes (wire cutters) and slide it under the head of that "screw" and pry up....if they are so pliable that they break you can get a bag of them from Honda for very cheap.....also you can try pushing from the bottom of the "screw" instead of pulling from the top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crafty »</TD></TR><TR><TD CLASS="quote">try not to push down to hard when you unscrew them...
or try prying the screw up from inbetween the washer and the screw while unscrewing it</TD></TR></TABLE>
Been there.. done that .. **** isnt budging
I removed my bumper as well to do a headlight swap. I found out that when i was turning them the little thing they go inside to hold them in place was spinning with it. So i used my finger and held that piece from spinning and i unscrewed the other thing and it worked out. Not sure if that helps you at all or not?
