Easy Tach Install
Hey,
Ok I just got dones installing my Autometer tach finally. So here is what I did, I found how to get a wire in the car, and only one. I took the old vents off where the clock goes, my std. model does not have one but the wires are there, I used the yellow, which is hot and the black is ground and it is already grounded. That made it easy, the other goes from the distributer to the tach. So basically all you have to do is run one wire from the dizzy and the others just connect them to the tach. I also made mounts for it out of some metal and bolted it to the dash. Dont know if any of you have done this before but.....
I will have pics up later!
Simon
Simon
