need to kno if i can use a 88-91 si ecu on my d16z6 and will it work?
Old Feb 8, 2004 | 07:56 AM
jspechatch04's Avatar
Default need to kno if i can use a 88-91 si ecu on my d16z6 and will it work?
hi i need to kno if i can use a d16a6 ecu on a d16z6 motor if i change the alternator and distirbutor will it work and i also need to kno if theres a easier way to use my z6 without changing to obd1 thanks
Old Feb 8, 2004 | 07:58 AM
Doug684's Avatar
Default Re: need to kno if i can use a 88-91 si ecu on my d16z6 and will it work? (jspechatch04)
You can but you will have to run a VAFC or something similar to control Vtec
Old Feb 8, 2004 | 08:00 AM
Default Re: need to kno if i can use a 88-91 si ecu on my d16z6 and will it work? (Doug294)
can i use a d16a6 tranny on it ?
Old Feb 8, 2004 | 08:19 AM
AaronJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspechatch04 &raquo;</TD></TR><TR><TD CLASS="quote">can i use a d16a6 tranny on it ?</TD></TR></TABLE>
yes
Old Feb 8, 2004 | 08:25 AM
Default Re: need to kno if i can use a 88-91 si ecu on my d16z6 and will it work? (AaronJ)
what else will i have to change to get get the motor to work?
Old Feb 8, 2004 | 09:59 AM
mr. carpenter's Avatar
you'll need to activate the v-tec w/ a rpm switch
Layziebtnh055
May 28, 2004 11:19 AM
jspechatch04
Feb 10, 2004 12:59 AM
Brownjd
Nov 4, 2003 12:57 PM
sweetcarz02
Jul 17, 2003 06:46 PM
