timing and afc
Old Feb 8, 2004 | 06:40 AM
zseeanz's Avatar
Default timing and afc
can the timing be adjusted with the afc? How do you retard or advance timing?
Old Feb 8, 2004 | 07:17 AM
boostsohfast's Avatar
Default Re: timing and afc (zseeanz)
The afc does not control timing.
You can manually delay your timing with a timing gun or go with something like a msd BTM (boost timing master) that allows you to adjust your timing with a ****.
Old Feb 8, 2004 | 07:23 AM
zseeanz's Avatar
Default Re: timing and afc (boostsohfast)
thanx. With the msd timing control, do you need an msd ignition sytem to work with that or does it splice right in with your stock setup?
mortificationrock
Jul 10, 2007 04:26 PM
88ZCRX
Jul 20, 2003 07:19 AM
