Type R heads for GSR??
Old Feb 8, 2004 | 04:46 AM
HondaRacer32's Avatar
Default Type R heads for GSR??
Are type R heads better than stock heads on a GSR motor, and why, also does anyone know any website on where i could look at any type r heads??
Old Feb 8, 2004 | 06:42 AM
ko's Avatar
ko
Default Re: Type R heads for GSR?? (HondaRacer32)
A type r head is a little better than a GSR. Stiffer Valve springs, better cams, etc. etc. Is it worth it? I dunno...I'm debating the same thing.
Old Feb 8, 2004 | 11:08 AM
b00sted4dr's Avatar
Default Re: Type R heads for GSR?? (DOHC hatch ej)
Better throttle body, intake manifold, cams, stiffer springs, and the head has a mild hand port job. It would be better.
Old Feb 8, 2004 | 11:26 AM
realfasthonda's Avatar
Default Re: Type R heads for GSR?? (96gsr4dr)
stock, the type r is better, but for a full build the gsr is better
Old Feb 10, 2004 | 06:22 AM
B18chb's Avatar
Default Re: Type R heads for GSR?? (realfasthonda)
Just wandering, why is a GSR head better for a full build? I'm not trying to dis you i really want to know.
Old Feb 10, 2004 | 06:32 AM
rodimus's Avatar
Default Re: Type R heads for GSR?? (B18chb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18chb &raquo;</TD></TR><TR><TD CLASS="quote">Just wandering, why is a GSR head better for a full build? I'm not trying to dis you i really want to know.</TD></TR></TABLE>
gsr head has pentroof style combustion chambers.
you will have more compression with gsr head.
SEARCH
Old Feb 10, 2004 | 04:20 PM
Default Re: Type R heads for GSR?? (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">
SEARCH</TD></TR></TABLE>
yep
Old Feb 10, 2004 | 05:10 PM
HEAD's Avatar
I like the injector location of the B18 more than the B16 too. (and also agree with evol) I think the R head is made to big when the factory does the their porting besides it looks like Ray Charles ported most that I have seen, not very preety and most racers in the NHRA and Nopi who run a honda and run a B series engine run the B18 head
Old Feb 10, 2004 | 05:12 PM
MrParks's Avatar
r heads are better all around and can be modified with gsr combustion chambers for good quench pad area and the valves on these heads are back cut and nitraited in my upinion if you do either head for perf i would go for the gsr cuz the r head is just to puurty
Old Feb 10, 2004 | 05:54 PM
rodimus's Avatar
Default Re: Type R heads for GSR?? (HARTENG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HARTENG &raquo;</TD></TR><TR><TD CLASS="quote">r heads are better all around and can be modified with gsr combustion chambers for good quench pad area and the valves on these heads are back cut and nitraited in my upinion if you do either head for perf i would go for the gsr cuz the r head is just to puurty</TD></TR></TABLE>
LOL nice sentence
Old Feb 10, 2004 | 06:14 PM
eyeamvic's Avatar
Anybody seen this?
http://www.alaniztechnologies.....html
Old May 3, 2004 | 04:44 AM
DragInteg's Avatar
From: MY GIRLFRIENDS MOMS HOUSE, NEW BERLIN, WI, USA
Default Re: (eyeamvic)
If you go with the type-r head, your compression will go down ~.385 pts and will hold up better under boost with its better valvetrain compaired to a stock gsr head. However, with the high cost of a type-r head, it is simply not worth the money It would be more economical and better performance wise if you buy a gsr head with bent valves (get one cheap) and send it out to PORTFLOW. You will end up with a new, built head for about the same amount of money as a type-r head, walking away with a stronger and more tolerable setup.
Old May 3, 2004 | 07:14 AM
Default Re: (DragInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragInteg &raquo;</TD></TR><TR><TD CLASS="quote">If you go with the type-r head, your compression will go down ~.385 pts and will hold up better under boost with its better valvetrain compaired to a stock gsr head. However, with the high cost of a type-r head, it is simply not worth the money It would be more economical and better performance wise if you buy a gsr head with bent valves (get one cheap) and send it out to PORTFLOW. You will end up with a new, built head for about the same amount of money as a type-r head, walking away with a stronger and more tolerable setup. </TD></TR></TABLE>
lol your 3 months late with your post
Old May 3, 2004 | 06:31 PM
DragInteg's Avatar
Default Re: (realfasthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realfasthonda &raquo;</TD></TR><TR><TD CLASS="quote">
lol your 3 months late with your post</TD></TR></TABLE>
Sorry, didn't sleep and was taking a break from typing a paper...wasn't paying any attention to the date but hopefully it is usefull info for someone else
dayaftertomorrow
Feb 13, 2006 02:03 AM
Tatakai
Sep 7, 2004 06:27 PM
moreno
19
Oct 30, 2003 07:59 AM
GSRoadRage
May 28, 2002 05:22 PM
Trajic
Aug 8, 2001 11:38 AM
