what exactly do you need for...
Guest
Posts: n/a
what exactly do you need for rear disc swap on 92-95's?
ive searched and got many different answers. i want to know exactly what i need to do it right. do i need MC, prop valve? trailing arm?
please make a list of exactly what parts are needed.
thanks.
thanks.
rear trailing arms w/ hub and spindle, calipers, rotors, and brake cables
http://www.sohfast.com/store/used/integra.asp
*scroll to the bottom of the motor swap set ups.
required parts to say the least:
-ebrake cables, brake lines
-rear hub complete with rotor and caliper
-usually using complete trailing arm with above parts is much easier then removing and swapping the hubs.
-prop 40/40 valve and MC/brake booster is not necessary but can be a great addon.
em2ssm02
Jul 15, 2006 08:09 PM
JSTOCK
Feb 25, 2002 08:13 AM
