under or overcamming this setup?
Old Feb 7, 2004 | 10:08 PM
lke2drvgsr's Avatar
Default under or overcamming this setup?
.25mm overbored 12:1 compression forged pistons (probably JE) and a 50-75 shot nitrous on skunk2 stage 2 cams? wondering if i'd be under or overcamming this setup..
Old Feb 7, 2004 | 10:13 PM
mr.beeks's Avatar
Default Re: under or overcamming this setup? (lke2drvgsr)
high lift cams?
high compression?
and nitrous?
is that a good set up?
what engine management?
Old Feb 7, 2004 | 10:14 PM
lke2drvgsr's Avatar
Default Re: under or overcamming this setup? (mr.beeks)
hondata s200.
and i don't know if its a good setup, that's why i was asking
Old Feb 8, 2004 | 11:05 PM
ScottFern's Avatar
those cams should be just right for that setup , but I wouldn't go near NOS.
Old Feb 9, 2004 | 07:24 AM
lke2drvgsr's Avatar
Default Re: under or overcamming this setup? (ScottFern)
is it true that CTR pistons yield a 12.4:1 CR in a b18c motor?
Old Feb 9, 2004 | 07:42 AM
StyleTEG's Avatar
Only one way to find out.
http://www.rbracing-rsr.com/comprAdvHD.htm
Find your crank pressure under stock conditions, and then do it again with the S2/12:1 conditions.
If you have raised your cranking pressure above 25% you are undercamming the engine. If you have dropped cranking pressure you are overcamming the engine.
EKB18C97
20
Dec 22, 2006 09:56 AM
slo97civic
Feb 23, 2005 08:14 AM
BME1986
Nov 17, 2003 12:38 PM
JDM CRX
Nov 8, 2002 01:47 PM
canuck-mx6
Jul 2, 2002 08:39 AM
