Are all civics wired for A/C?
Old Feb 7, 2004 | 09:48 PM
1CiViC1's Avatar
Default Are all civics wired for A/C?
Was i wrong to assume that all civics are wired for a/c? I always thought that hondas came prewired...well, Im going to put a/c in my STD hatch (commuter). I ran into a few problems:
heres where the ac push button would be, the plug is there so im ok here.
this is a shot of the evap core, the white object in the middle has a 2prong plug, i cant find where it plugs into!
this is the line under the battery going from the condensor to the evap core. 2prong, no harness plug anywhere.
heres another shot of the evap core (left) blower (right) once mounted theres a huge gap (center). do i need a blower from a car with ac? or are all blowers the same? whats wrong here?
any help/input is appreciated. TIA
Old Feb 7, 2004 | 11:22 PM
1CiViC1's Avatar
Default Re: Are all civics wired for A/C? (1CiViC1)
ttt
Old Feb 8, 2004 | 08:05 AM
4drEF's Avatar
Keyboard Humorist
You need the A/C harness. It's not part of the engine harness - it's it own seperate harness.
I did a car up with A/C before and everthing ekse is there to add the A/C system. you don't need to replace anything, but you do need to add everything else.
Old Feb 8, 2004 | 09:23 AM
xci_ed6's Avatar
Default Re: Are all civics wired for A/C? (4drEF)
I think I have an A/C harness laying around, I just removed my a/c. It has a plug above the ECU where the engine harness meets the interior harness.
PM me.
-Dustin
Old Feb 8, 2004 | 11:17 AM
1CiViC1's Avatar
Default Re: Are all civics wired for A/C? (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">I think I have an A/C harness laying around, I just removed my a/c. It has a plug above the ECU where the engine harness meets the interior harness.
PM me.
-Dustin</TD></TR></TABLE>
when i was searching i do remember seeing a plug on the harness that didnt match anything, it was right above the ecu. thanks! so the harness plugs in there, then the remainder of the ac harness plugs into the evap core, thru the fire wall to the compressor, fan and switch?
Old Feb 8, 2004 | 03:06 PM
xci_ed6's Avatar
Yup thats it.
-Dustin
Old Feb 8, 2004 | 06:03 PM
1CiViC1's Avatar
im'd ya dustin
Old Feb 9, 2004 | 10:42 AM
1CiViC1's Avatar
wiring in the works
ok, what about the gap in the evap core and the blower?
is there a difference in the blower? do i need one from a car with ac? My evap core is outta a 4dr, is that the problem?
*The other side of the evap core fits fine. Ive tried to move the blower housing over but that was a no go...
Old Feb 9, 2004 | 11:45 AM
B1TEM3's Avatar
you would need the clamp, i think there is two of those
the one between the blower and the evap
the other is between the evap and the main hose (on the picture)
the clamps are also from the civic that has A/C
Old Feb 9, 2004 | 12:30 PM
johnzm's Avatar
Default Re: Are all civics wired for A/C? (B1TEM3)
i alsohave an AC harness and the button for the climate control for 90 civic too!
Old Feb 9, 2004 | 05:04 PM
1CiViC1's Avatar
Default Re: Are all civics wired for A/C? (johnzm)
ok, got the clamps! problem solved
evilclown312
Mar 29, 2011 07:37 PM
eghatchfla
Sep 15, 2010 06:21 PM
B20TRIZ
Mar 29, 2010 02:36 PM
EJ1 wilcox
21
Jan 7, 2008 11:49 AM
ls95hatch
11
Apr 18, 2004 10:23 PM
