90-93 integra radiator in 90 hatch
Old Feb 7, 2004 | 08:53 PM
tealegg's Avatar
Default 90-93 integra radiator in 90 hatch
like the topic says, will it work with a litte fab. any one tried it?
Old Feb 7, 2004 | 09:51 PM
Davep's Avatar
Default Re: 90-93 integra radiator in 90 hatch (JDustinM)
Yes you can do this with out to much work at all.
You can see at the bottom of the 90-93 rad the parts that have to be cut off because they hit the crossmember.
Old Feb 9, 2004 | 08:47 AM
tealegg's Avatar
thanx for the info!
Old Feb 9, 2004 | 08:53 AM
UNDER PRESSURE's Avatar
Default Re: (JDustinM)
Are you sure that it will clear the hood? Cause I tried it on my crx and it didn't clear the hood
Old Feb 9, 2004 | 09:10 AM
Davep's Avatar
Default Re: (UNDER PRESSURE)
It fit ok in my car.
Old Feb 9, 2004 | 09:38 AM
R6Boy69's Avatar
It drops right in... might have to cut away some of the platic pieces that are sticking out on the bottom but its not that hard at all to do...
Old Feb 9, 2004 | 09:53 AM
Nerologic's Avatar
is this mod worth the hassle? i mean is it much better then the stock ef one?? and anyone here succesfully installed a DC integ radiator??
Old Feb 9, 2004 | 10:35 AM
Davep's Avatar
Default Re: (Nerologic)
I did it when the stock unit need to be replaced.
Old Feb 9, 2004 | 11:04 AM
slow91hatch's Avatar
i have one in my car right now, it does close kinda tight, but i think thats partially related to a minor accident my car saw a few owners ago with the front. to be honest, if you are planning on a turbo or anything that goes behind it, just get a eg one.
Old Feb 9, 2004 | 12:32 PM
johnzm's Avatar
Default Re: (slow91hatch)
the rad was much thicker than my oem 90 SI civic one. its a tight fit, but i had it in for 3 months and no fan on it temps never moved!
for allmotor apps i would reccomend it for turbo its much toolarge and prolly the turbo would hit it
Old Feb 9, 2004 | 07:33 PM
tealegg's Avatar
yea i just got it off my buddy for 15 dollars. its in real good shape. mine is so haggard lol lets just say JB weld own! haha it will go in tomorrow
Old Feb 9, 2004 | 08:28 PM
WWDTrackRacer's Avatar
New User
Default Article @ Hybrids.Jp
http://honda.hybrids.jp/tech/h...shtml
The modine radiator lower mounting nubs cracked off on me, dunno
if this was a track driving stress-issue -- it did mount very
snug so the vibration probably caught up to it and broke them
off. Just keep an eye on it.
Old Jun 19, 2005 | 06:06 PM
Garrett's Avatar
Default Re: Article @ Hybrids.Jp (WWDTrackRacer)
It seem to be entierely bolt on right?
Old Jun 19, 2005 | 09:29 PM
PURPLETERROR aka BIGMATT's Avatar
Yes it bolts right in, just make sure you use 92-93 gsr rad hoses as the inlel and outlet are larger than the stock radiator.
Old Jun 19, 2005 | 09:40 PM
eda6's Avatar
Default Re: Article @ Hybrids.Jp (Garrett)
The radiator itself fit perfectly in my hatch. Modded the radiator fan to clear the header and used a radiator cap w/o pressure relief valve so the hood would close.
Old Jun 20, 2005 | 03:53 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNDER PRESSURE &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure that it will clear the hood? Cause I tried it on my crx and it didn't clear the hood</TD></TR></TABLE>
The problem here is that different makes of 1990-1993 Integra radiators will fit a 1988-1991 car differently. I, for instance, tried using an exact OEM dual core replacment radiator. And I had this exact problem. But I stumbled upon a CSF all metal radiator in good condition at the loacl Pick-And-Pull. And fitment couldn't be better. NO modifications of ANY kind were necessary. So just keep in mind that if you are trying to use a 1990-1992 Integra radiator in an ED/EF, not all brands will fit easily. One more thing. CSF also makes a 1988-1991 Civic/CRX dual core radiator. But keep in mind that this radiator has smaller hose nipples. So the Integra radiator is a better idea for B-series swaps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WWD &raquo;</TD></TR><TR><TD CLASS="quote">
TrackRacerThe modine radiator lower mounting nubs cracked off on me, dunno
off. Just keep an eye on it.</TD></TR></TABLE>
I have had the same problem with Modine radiators.
Old Jun 20, 2005 | 04:26 AM
g2tegsown's Avatar
I haven't tried it yet but I have a CSF Dual Core All Aluminum radiator in my Teg (93 RS) and it looks like it's gonna "plug n play" in my '89 CRX Si
Old Jun 20, 2005 | 06:10 AM
mike-y's Avatar
if you can get one for CHEAP, its worth the hassle. Like who ever got the one for $15.
but if you are buying a new radiator, just get a 88-91 civic wagon radiator, or a heavy duty version for an 88-91 civic/crx. the wagon and HD ones are dual core and a perfect fit (no ghetto fabbing!). Some aftermarket companies sell single core rads for wagons though, so be sure to check first.
Old Jun 20, 2005 | 02:49 PM
Default Re: 90-93 integra radiator in 90 hatch (mike-y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">if you can get one for CHEAP, its worth the hassle. Like who ever got the one for $15.
but if you are buying a new radiator, just get a 88-91 civic wagon radiator, or a heavy duty version for an 88-91 civic/crx. the wagon and HD ones are dual core and a perfect fit (no ghetto fabbing!). Some aftermarket companies sell single core rads for wagons though, so be sure to check first.</TD></TR></TABLE>
However, the Integra radiators do have one great advantage: larger hose nipples for those of us with B-series swaps.
Old Jun 20, 2005 | 05:39 PM
John McClane's Avatar
my DB radiator fits without 'ghetto fabbing'
Old Jun 21, 2005 | 01:59 AM
Default Re: (RockTheMullet)
I also recommend you go with an aftermarket rather than factory radiator. Factory radiators seem to be quite application specific. So a factory Integra radiator will have certain design features that make it unsuitable for a Civic. But aftermarket companies seem to like to use the same design for as many applications as possible to save money, changing only what is absolutely necessary. This makes them a better fit.
Old Jun 21, 2005 | 05:39 AM
nitrousrush's Avatar
I also have one in my ride goes right in very easy ...
Old Oct 26, 2020 | 02:03 AM
YoungBoii02's Avatar
I got mine without the fan but the rad gets really hot, should I put a fan back on or leave it that?
EZ$$EF
Oct 29, 2007 10:15 PM
Efbucket
Oct 17, 2007 10:21 AM
1990hondaHF
Aug 20, 2007 04:45 PM
t . b o z
Dec 26, 2004 04:04 PM
Nerologic
Nov 5, 2003 10:44 PM
