JDM foglight problem!!! help!
Old Feb 7, 2004 | 04:01 PM
JDM_Type-R's Avatar
Default JDM foglight problem!!! help!
k i thought my bulb went out..so i replaced it with a brand new bulb, h3 55 w, but it still wont light up! has this happened to anybody else? anything i can do to solve the problem? any help is appreciated greatly. thanks!!
Old Feb 7, 2004 | 04:59 PM
JumboJoe's Avatar
Default Re: JDM foglight problem!!! help! (JDM_Type-R)
Did you check the fuses and all electrical connections?
Old Feb 7, 2004 | 05:01 PM
canuck-mx6's Avatar
Either the bulb is bad, the fuse is blown, or you have a short somewhere. Try swapping bulbs to test the bulb/wiring
Old Feb 13, 2004 | 01:07 AM
JDM_Type-R's Avatar
Default Re: JDM foglight problem!!! help! (canuck-mx6)
the bulb isnt bad...
how do i check if the fuse is blown?
and if it is, how do i replace it?
Old Feb 13, 2004 | 03:38 AM
98R-1144's Avatar
if you wired it correctly, you should have either used:
a power wire connected to the battery (or relay) with an inline fuse
OR
the stock fog light power wire (which i think uses the fuses under the steering wheel)
check either of them to see if the fuse blew.
Old Feb 13, 2004 | 08:36 AM
JDM TypeR 307's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Type-R &raquo;</TD></TR><TR><TD CLASS="quote">the bulb isnt bad...
and if it is, how do i replace it?</TD></TR></TABLE>
not knowlegdable about cars!!
ant13
Feb 10, 2014 01:44 PM
-Racer X-
Jun 30, 2013 04:56 PM
batzcivic
11
Aug 20, 2005 09:11 PM
tgctruly
Oct 17, 2004 08:51 PM
obsidianG35
Sep 12, 2003 01:50 PM
