upgrade 9.5 to 10.3 inch brakes on del sol si?
Old Feb 7, 2004 | 12:25 PM
NINJASPY's Avatar
Default upgrade 9.5 to 10.3 inch brakes on del sol si?
what is needed to upgrade 9.5inch 93 del sol si(sohc z6), to dohc vtec 10.3 inch brakes? calipers the same? hubs?
thanks
Old Feb 7, 2004 | 12:35 PM
Solracer's Avatar
Default Re: upgrade 9.5 to 10.3 inch brakes on del sol si? (NINJASPY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJASPY &raquo;</TD></TR><TR><TD CLASS="quote">what is needed to upgrade 9.5inch 93 del sol si(sohc z6), to dohc vtec 10.3 inch brakes? calipers the same? hubs?
thanks </TD></TR></TABLE>
What do you need to upgrade for aka what are you doing with your car is it stock? If it is stock, I run plenty of track events with the stock SI brakes and they stop me well enough.
If your car is stock I would suggest new brake fluid and betters pads and if need new rotors.
If not I belive you would need the calipers from a Del Sol Vtec or GSR, but it has been a long time since I have looked into doing that.
Old Feb 7, 2004 | 02:03 PM
Crank's Avatar
Default Re: upgrade 9.5 to 10.3 inch brakes on del sol si? (Solracer)
do a 5-lug
Old Feb 7, 2004 | 02:08 PM
locass316's Avatar
kunkles, calipers, hubs. just look for a integra front brake setup. they should come with everytihgn you need
Old Feb 7, 2004 | 02:41 PM
Hash Browns's Avatar
I believe you could just go with the entire front knuckle off of a 92-95 Civic Ex w/10.3" fronts, 94-97 Del Sol VTEC, 96-97 Del Sol Si, 94-00 Integra (all models but Type-R). The 92-95 Civic Si may have had the 10.3" fronts also.
Old Feb 7, 2004 | 08:53 PM
NINJASPY's Avatar
Default Re: upgrade 9.5 to 10.3 inch brakes on del sol si? (Hash Browns)
I aquired a set of 10.3 rotors for free and want to use them.
Old Feb 7, 2004 | 09:04 PM
FrostySol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hash Browns &raquo;</TD></TR><TR><TD CLASS="quote">I believe you could just go with the entire front knuckle off of a 92-95 Civic Ex w/10.3" fronts, 94-97 Del Sol VTEC, 96-97 Del Sol Si, 94-00 Integra (all models but Type-R). </TD></TR></TABLE>
what he said
eg2jr
Apr 27, 2008 08:39 PM
DelSolMarine
Aug 23, 2007 06:36 PM
ivicr
11
Oct 5, 2006 10:03 PM
tambara
Jul 29, 2006 07:43 AM
one_stinky_bum
11
Apr 2, 2005 07:12 PM
