Not to sure what ratio piston,s I should get Help out!
I'm going to buy a dart block 2.0L from this place in Cal. The person I buying the block from is going to do the complete block (crank,piston,rods) I was thinking about going with 13.5:1 but the guy didn't recommend it. So my question is what ratio piston should i go with?
all motor integra in the works
so far all I have is
toda cams
toda retainers
I think there called ferral vales
Aem cam gears
block is in the making
type-r tranny
GSR head
Sk Man
spoon had gasket
Things I need to fin.
header
Port and ploish the head
thottle body
Ecu
fuel rail
injectors
dam I still need alot of things to fin. But I'm taking my time and doing it right the first time.
give me some info on what you think. I'v been doing this project for almost a year now.
toda cams
toda retainers
Aem cam gears
type-r tranny
GSR head
Sk Man
spoon had gasket
header
thottle body
Ecu
fuel rail
injectors
