How does my timing look?
Old Feb 7, 2004 | 10:20 AM
Origin's Avatar
Default How does my timing look?
i think i have done everything correctly but would someone varify if i did. i just dont want to bend some valves before i ever get the thing started up.
crank at tdc
http://www.we-todd-did-racing....D.jpg
cams without timing belt
cams with timing belt
(sorry about the finger )
and ive torqued the tensioner back down. did i miss anything? thanks.
Old Feb 7, 2004 | 10:41 AM
CrX-To-Tha-Max
Guest
Posts: n/a
Default Re: How does my timing look? (Origin)
right on mark
Old Feb 7, 2004 | 11:18 AM
96-EJ6 B18C's Avatar
Default Re: How does my timing look? (CrX-To-Tha-Max)
Looks good to me.
EDIT: Pull the plugs out of it, and turn it over a few time by hand and check the timing again and you should be set!
Old Feb 7, 2004 | 12:32 PM
Origin's Avatar
Default Re: How does my timing look? (96-EJ6 B18C)
cool. thanks guys
Old Feb 7, 2004 | 12:37 PM
JCracer723's Avatar
is it just me or the belt looks kinda hmmm iono funny .. curved all the way like that
Old Feb 7, 2004 | 01:56 PM
b16_madman's Avatar
Default Re: How does my timing look? (JCracer723)
Capt. Obvious thinks that it was still loose when he took the picture.
Old Feb 7, 2004 | 02:57 PM
tilt's Avatar
good job.
just dont forget, before you tighten the tensioner turn the crank a few teeth so the belt is taught between the camgear and crank pulley.
Old Feb 7, 2004 | 03:39 PM
MLogan's Avatar
You can always take out a spark plug and put a screwdriver in. When the screwdriver gets to the highest point, that piston is at the top. Then check to make sure you marks line up.
f20beme
Apr 13, 2015 04:34 AM
piotrush
Nov 20, 2006 04:13 AM
efyou
Jul 1, 2006 10:07 AM
909rex
Apr 10, 2004 01:53 PM
