b16a swap!!!!!!!!!!
Old Feb 7, 2004 | 07:21 AM
jsteezy1290's Avatar
Default b16a swap!!!!!!!!!!
hey im wondering what websites are a good step by step to puttin a b16a in a 89 si crx.. i bought the motor cable tranny shift linkage and motor mounts and he said a plug and play wiring harness so i will have to do no wiring . i dont know if this is true because i havent received the package yet. and he claims the axles and halfshafts will fit too. but just in case i run into problems i want a website i can go to see what the heck im doing.. any info would be great guys
Old Feb 7, 2004 | 07:29 AM
silverCRXTC's Avatar
Default Re: b16a swap!!!!!!!!!! (jsteezy1290)
If its a JDM harness it wont work, was this motor already in a usdm CRX?
Old Feb 7, 2004 | 04:04 PM
nope dude says its straight from japan
Old Feb 7, 2004 | 06:58 PM
u need to throw on the motor a si/hf harness and run 4 wires for the vtec goodies, its cake, try using the search function. Also u need a mount system, go HASPORT imo, u cant go wrong.
Old Feb 9, 2004 | 06:47 AM
do you have a wiring diagram for me to use?
Old Feb 9, 2004 | 07:03 AM
jlicrx's Avatar
Default Re: b16a swap!!!!!!!!!! (silverCRXTC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverCRXTC &raquo;</TD></TR><TR><TD CLASS="quote">u need to throw on the motor a si/hf harness and run 4 wires for the vtec goodies, its cake, try using the search function. Also u need a mount system, go HASPORT imo, u cant go wrong.</TD></TR></TABLE>
you MUST use the Si engine harness - HF harness is not interchangeable with Si
Old Feb 9, 2004 | 03:11 PM
Default Re: b16a swap!!!!!!!!!! (jlicrx)
u could use the hf and change some **** around its mpfi there might be a couple stupid things, GOTO http://www.hasport.com they will get u started on a swap
Old Feb 9, 2004 | 04:13 PM
DBallz's Avatar
Heh I have a question for you my buddy has a 89 Si and he wanted to dump so much moeny in pistons rods and head work I just said to get a swap. So we found this JDM b16a with everything you need inclusind a/c but do you know if he can use the a/c compressor in the CRX will it fit?
Old Feb 9, 2004 | 04:57 PM
virginia_dude's Avatar
Default Re: b16a swap!!!!!!!!!! (DBallz)
JDM A/C only works if you get custom A/C lines made. And if you use the US market one you need custom mount bracket. Take my word on it, I am almost finished with the same swap.
Old Feb 9, 2004 | 05:34 PM
Default Re: b16a swap!!!!!!!!!! (virginia_dude)
i have a si so i would use the si harness right? the company im getting the b16 from said i wont have to wire anything because the wiring thats coming with the motor is gonna be prewired
Old Feb 9, 2004 | 06:37 PM
believe me you can repin a SiR engine harness to work, but its a hell of a lot of work, and you still need a good harness to match it to, and if you have that whats the point.
Take my word on it. I have been working on doing just that. It ain't easy.
Old Feb 9, 2004 | 08:34 PM
jlicrx's Avatar
here are the wire locations and functions for the HF and Si engine harnesses where they plug into the firewall - they are not the same and are not interchangeable
Old Feb 9, 2004 | 09:07 PM
Rywire's Avatar
my site has a lot of info on the swap. http://www.geocities.com/droppedcrxsi
go to b16 swap
Old Feb 14, 2004 | 01:18 PM
Default Re: b16a swap!!!!!!!!!! (droppedcrxsi)
do i need axles and halfshafts to do the swap? i know i need motor mounts
Old Feb 14, 2004 | 02:20 PM
JrCRXHF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
you MUST use the Si engine harness - HF harness is not interchangeable with Si</TD></TR></TABLE>
when i did my swap at payn we used my HF harness to do the swap the only bitch was doing the knuckel swap.
Old Feb 14, 2004 | 02:27 PM
JrCRXHF's Avatar
to make your life eaiser and to have the job done right you should bring you car to payn tech in troy michigan and have him do your swap do the timming belt water pump and put hondata on the car and he can do a dyno tune for you right there on the spot and then your car well be all set just like it came from the factory with that motor he does really good work and it will be done right the first time.
i know it is not a B16 but this is some of his work on a JR supercharger. but a really clean engin bay.
Old Feb 14, 2004 | 07:22 PM
Default Re: b16a swap!!!!!!!!!! (JrCRXHF)
how much will the labor cost for the swap
Old Feb 15, 2004 | 05:03 PM
DIY save money buy more parts and learn a thing or two. plus if u get stuck hondatech can help out
Old Feb 15, 2004 | 07:42 PM
civais's Avatar
What mounts are you going with?
Old Feb 16, 2004 | 04:46 PM
Default Re: b16a swap!!!!!!!!!! (civais)
not sure yet but i dont think im getting hasport ones
Old Feb 16, 2004 | 04:57 PM
JrCRXHF's Avatar
you will have to call and ask. http://www.payntechnologies.com
Old Feb 16, 2004 | 05:06 PM
propaint's Avatar
get hcp mounts from newman
Old Feb 16, 2004 | 06:03 PM
Default Re: b16a swap!!!!!!!!!! (propaint)
from newman how much?
Old Feb 16, 2004 | 06:48 PM
wpgcivic's Avatar
hey man i got cheapo mounts from ebay and am getting shifter linkage custom made, i have a dx with mpfi right now but i am getting someone to add like 4 wires for vtec, etc...also i got 90-93 ls teg axles which you will also need, and also rad hoses and a trottle cable from a 90-93 teg. hope this helps, i am also in the process of doing my b16a swap in my ef civic
Old Feb 17, 2004 | 07:16 AM
Default Re: (wpgcivic)
how much you want?
