Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
OT: air compressor maintenance.. leave it full or empty?
Old Feb 7, 2004 | 07:00 AM
sykikchimp's Avatar
Default OT: air compressor maintenance.. leave it full or empty?
In the instructions for my new air compressor it says to empty the air out of the tank after every use. I honestly haven't used air compressors a lot in my life, and don't know if this is absolutely necessary. Seems kinda silly..
I would prefer to leave it full all the time, so it's easy to just go out into the garage, and use..
Should I follow the instructions and empty it? or leave it full all the time?
what do you do with yours?
Old Feb 7, 2004 | 07:24 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: OT: air compressor maintenance.. leave it full or empty? (sykikchimp)
if you arent using it you should empty it. moisture in the air that it intakes can rust the tank out. i work in a metal shop and we empty ours out after every use... if you put your hand under the plug when it is emptying, you will feel the moisture!
Old Feb 7, 2004 | 08:01 AM
Want2race's Avatar
Default Re: OT: air compressor maintenance.. leave it full or empty? (MMsportsRexSi)
i empty mine but i think in reality that water will still remain inside and the open drainwill allow oxygen to move around and rush will probably happen both ways..
dunno...
Old Feb 7, 2004 | 08:15 AM
Targa250R's Avatar
be professional
I empty mine after every use; I only use it once or twice a week. Condensation comes out every time. Only takes a few minutes or so to fill up anyway, which is about the time it takes me to get out the impact gun and oil it up, and get the car up on jackstands or whatever.
We regularly empty the compressors (usually once a day) at the Honda dealership to let out the moisture that builds up inside so the tanks don't rust out.
Old Feb 7, 2004 | 06:57 PM
sykikchimp's Avatar
That's what I needed. thanks guys!..
Old Feb 7, 2004 | 07:00 PM
travis's Avatar
Default Re: (sykikchimp)
Another vote for empty. Even if there's still moisture in the tank when empty, there's still less total water.
Old Feb 7, 2004 | 07:03 PM
MLogan's Avatar
This is good information, I never knew it had to be released every time.
I just had a quick question about oiling. I know you are supposed to oil after every use, do you just oil where the air hose connects and how much do you usually put in?
Old Feb 7, 2004 | 07:24 PM
MattG's Avatar
New User
I have heard you can get a special valve that will automatically drain the water by opening for a short period of time. I saw it on a TV car/garage show, but have yet to see one in person. Could be a good idea if you want to keep it full.
Old Feb 7, 2004 | 07:34 PM
TeamNextGenChris's Avatar
me and my dad have had the same compressor in the shop for about as long as i've been around(he's had it 20+ years).we never empty it,never had a problem.
chris
Old Feb 7, 2004 | 07:35 PM
Targa250R's Avatar
be professional
Default Re: OT: air compressor maintenance.. leave it full or empty? (MLogan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLogan &raquo;</TD></TR><TR><TD CLASS="quote">I just had a quick question about oiling. I know you are supposed to oil after every use, do you just oil where the air hose connects and how much do you usually put in? </TD></TR></TABLE>
Check the instruction manual for your gun. Some guns have oil fittings, and some guns you just squirt some oil into the air fitting. I oil mine before every use, it's a 1970s-era Craftsman and I'd say it's lasted for quite a while.
Old Feb 7, 2004 | 09:44 PM
markpaco's Avatar
Default Re: OT: air compressor maintenance.. leave it full or empty? (Targa250R)
a friend of mine said to leave it full so that you can always have air handy. I was like 'ok'. So I would leave it full and refill it as needed. So then one day (6 mos. later) I decided to drain it. All this rusty water came out of it. I drain it all the time now.
Long story short: Drain it
Old Jun 8, 2010 | 07:50 PM
vanser3004's Avatar
By the way what is the "special" Honda-compressor oil should I use in 2002 civic? (it says at the sticker under hood that I can find it at manual, but I can't). If somebody knows
a part number I will appreciate.
Old Jun 9, 2010 | 04:03 AM
Stinkycheezmonky's Avatar
Suspetise...
Are you talking about the AC compressor? This isn't really the right place for that question
HONDAAREFORME
10
Apr 21, 2005 02:19 PM
dabrown
Mar 15, 2004 09:01 AM
AzntaggeR
Aug 6, 2003 09:29 AM
43MA
Jan 16, 2003 05:02 PM
