HELP!! GSR/EG swap wiring
Old Feb 7, 2004 | 06:12 AM
andyboy's Avatar
Default HELP!! GSR/EG swap wiring
Im putting a 2000GSR into my 93cx hatch with a p08 ecu...
i cant get the wires to line up! can someone who did a similar swap please help me out with some diagrams?
i need the gsr ecu pinout diagram and the harness pinout diagram.
i searched hybrid garage and the diagram is way to small to read!
i also did a search here and all the diagram links were broken.
please help
Old Feb 7, 2004 | 07:05 AM
Andres-eh2's Avatar
Default Re: HELP!! GSR/EG swap wiring (andyboy)
http://www.c-speedracing.com/h...p.php
Old Feb 7, 2004 | 07:17 AM
andyboy's Avatar
Default Re: HELP!! GSR/EG swap wiring (Andres-eh2)
checked already but no help!
Old Feb 7, 2004 | 08:12 AM
Harassing Herbs's Avatar
should just get an obd2 gsr/type r engine harness everything plugs right up. the only wire u will have to run is off the blue wire from the dizzy for the tach, & u can connect this at the shock tower.
Old Feb 7, 2004 | 09:55 AM
itsm3paul's Avatar
Default Re: HELP!! GSR/EG swap wiring (Harassing Herbs)
also need help with the wirring got the vtec in but no secondary no knock and that should be it is this bad running without the wires hooked up?!?!?
Old Feb 7, 2004 | 10:21 AM
mrbsponge's Avatar
Default Re: HELP!! GSR/EG swap wiring (itsm3paul)
These links may help you some. They sure did with mine.
https://honda-tech.com/zerothread?id=744309
https://honda-tech.com/zerothread?id=744412
Old Feb 7, 2004 | 02:17 PM
saleensolution's Avatar
Default Re: HELP!! GSR/EG swap wiring (mrbsponge)
you can use a single cam P28 ecu but it has lower rev limiter in it, but you can get it reprogramed for whar you are doin. or you can just go ahead and get a P72 ecu out of a 94-95 gsr. i may be able to locate either for you. drop me a line
Old Feb 8, 2004 | 07:58 PM
darrinbrewer's Avatar
Default Re: HELP!! GSR/EG swap wiring (saleensolution)
this should help out.
Old Feb 10, 2004 | 05:52 AM
Default Re: HELP!! GSR/EG swap wiring (darrinbrewer)
darrin you are the man
elnene_14
Oct 23, 2013 11:59 AM
BigAnteg
Jun 6, 2009 05:13 PM
I Hate Chassis Codes
Jul 10, 2006 06:53 PM
7mile
Aug 29, 2005 11:16 AM
andyboy
Feb 10, 2004 05:51 AM
