Timing belt w/ LSvtec
I have a question.... i'm running a ls vtec and i was wondering what i need to run a gsr timing belt... i couldnt really remember but i remember it was something like if i ran a gsr oil pump or water pump then i need to run the gsr timing belt instead of the LS one... anyone know for sure which component i needed to use in order to use the gsr timing belt?? also do anyone know how to tell the difference from a gsr and a LS oil pump?? 94-95 is the year... thanks in advance
in order to run a gsr belt you have to use a gsr water pump. i would just use a ls water pump and timing belt and redline water wetter. as for the oil pump you you would have to open it up and count the teeth on the gear for that one, im not sure how to identify it physically.
Justintegra
Apr 20, 2008 12:46 PM
B18 CYA
May 11, 2005 03:11 PM
