i was wondering about type r final drive
Old Feb 6, 2004 | 09:15 PM
gsr98teg's Avatar
Default i was wondering about type r final drive
what is this goin to do for my car?
make its acceleration better?
how badly will my gas milage suffer?
and i wont have as high of a top speed will i??
lemme know wut u guys think of this mod
OR
Old Feb 6, 2004 | 09:18 PM
Kendall's Avatar
If you are referencing a USDM ITR final drive, then it will do nothing as it's the exact same as the one you have. A JDM ITR final drive will however improve your acceleration a bit, at the cost of gas milage and top speed. I suggest you research the topic as it has been covered many times in the past.
Old Feb 6, 2004 | 09:20 PM
Ti3d in's Avatar
Default Re: i was wondering about type r final drive (gsr98teg)
A JDM ITR final drive uses a lower gear, and will ultimately give you better acceleration. Your gas mileage will go down slightly, and top speed will be slightly slower due to the gearing. Also your RPM will be slightly higher at any given speed, so take that into consideration if you're nitpicky about highway noise.
s2kkid
Sep 27, 2004 12:58 PM
RiCE On IcE 2
Jan 13, 2003 01:04 PM
OK
Nov 5, 2001 05:57 PM
B2FiNiTY
Oct 18, 2001 05:46 PM
rezaroy
Aug 27, 2001 04:01 PM
