Are '88-'00 LS Water Pumps the same Part #?????
Old Feb 6, 2004 | 06:18 PM
MugenB16A2's Avatar
Default Are '88-'00 LS Water Pumps the same Part #?????
I have a guy at work with an '88 Integra LS, and he needs a new water pump, and I have the one off my '95 B18B1 block, that I would like to give to him, but I want to be sure it will work properly.
Do they share the same part number throughout the years????
Remember his is a 1988 and I have a 1995 Water Pump.
Thanks
Old Feb 6, 2004 | 10:19 PM
ProJectCvic's Avatar
Default Re: Are '88-'00 LS Water Pumps the same Part #????? (MugenB16A2)
no, they are not. The b18a block waterpump and the b18b waterpump are the same but 88 integer does not have the b18 block. i believe it was like a D16something (corrected me if i m wrong).
Old Feb 6, 2004 | 10:20 PM
Kendall's Avatar
Default Re: Are '88-'00 LS Water Pumps the same Part #????? (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">no, they are not. The b18a block waterpump and the b18b waterpump are the same but 88 integer does not have the b18 block. i believe it was like a D16something (corrected me if i m wrong). </TD></TR></TABLE>
Correct, the first gen Integra came with the D16A1. But all the waterpumps from 1990-2001 Integra's are interchangable. If you can, upgrade to a GSR water pump.
check what engine he has. Like i say, b18a and b18b water pump are the same.
AiL45
Oct 27, 2006 03:28 PM
tegasaurus
Feb 22, 2005 07:51 PM
MugenB16A2
Feb 6, 2004 09:48 PM
