Pads on 4 piston calipers
Old Feb 6, 2004 | 03:07 PM
swlabhot's Avatar
Default Pads on 4 piston calipers
What is the tool that I need to resetting the 4 pistons back in place when replacing the brake pads? Whats it called or look like? How does people with Spoon calipers replace their pads? Forcing it back by hand manually? Any pics will be v.nice..
Old Feb 6, 2004 | 03:10 PM
ITR Factor's Avatar
That secret tool is the end of a ratchet! or screw driver... you can do it with your fingers if your strong enough, just push one side of the the pistons in, place the pad in, then same thing on the other side..thats the way i do it on my spoon calipers atleast.
Old Feb 6, 2004 | 03:11 PM
thk's Avatar
thk
Members Only
Default Re: Pads on 4 piston calipers (swlabhot)
Old Feb 6, 2004 | 03:15 PM
len's Avatar
len
I just use big channel locks.
scrapes? what scrapes?
Old Feb 6, 2004 | 03:19 PM
swlabhot's Avatar
Default Re: Pads on 4 piston calipers (len)
When I did the stock caliper with my bare hands it was a real bitch. I had to use my whole bodyweight to pull them back! I could have dragged the whole car with me.....and that was just 1 piston, so I thought with 4 pistons I thought it would be even harder..
Thk - Is that a tool specifically for 4 pistons or just any caliper in general?
Old Feb 6, 2004 | 03:22 PM
TypeR 599's Avatar
why don't you try a C-clamp and place the old pad between that and the piston. that's what i do on my stock, i dont see why it wouldn't work with 2 pistons
Old Feb 6, 2004 | 03:27 PM
itrsport.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">How does people with Spoon calipers replace their pads? Forcing it back by hand manually?</TD></TR></TABLE>
I was able to push them back in with my hands. I'm not a superweight either so most people should be capable of doing this.
Old Feb 6, 2004 | 03:42 PM
Jasper_db1's Avatar
I use a C-Clamp on my Wilwood Dynalite calipers
Old Feb 6, 2004 | 03:50 PM
esponet's Avatar
stick a screw driver between the pads and the rotors and push it back in.
Old Feb 6, 2004 | 05:11 PM
type r 01-1063's Avatar
C-clamps work for me
Old Feb 6, 2004 | 06:59 PM
vactor's Avatar
i got a piston pusher at pep boys for like $4 ... like a C clamp with a pad shaped piece of metal welded to 1 end. works like a dream and VERY worth the $4 ...
Old Feb 6, 2004 | 07:29 PM
thk's Avatar
thk
Members Only
Default Re: (vactor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vactor &raquo;</TD></TR><TR><TD CLASS="quote">i got a piston pusher at pep boys for like $4 ... like a C clamp with a pad shaped piece of metal welded to 1 end. works like a dream and VERY worth the $4 ...</TD></TR></TABLE>
That's nice and it works for sliding calipers.
How do you suggest to use that with a fixed four piston caliper?
Old Feb 6, 2004 | 08:46 PM
Black R's Avatar
25 Year Member
I do it with my fingers..... quite easy actually.
Old Feb 6, 2004 | 09:31 PM
vactor's Avatar
Default Re: (thk)
whoops, forgot that this was 4 piston calipers
type r 01-1063
Aug 1, 2005 10:47 AM
FlyZlow
19
Jan 23, 2005 01:01 PM
ABTDer
May 8, 2003 10:11 PM
carblegal
Apr 9, 2003 09:51 PM
