offset question...
Old Feb 6, 2004 | 02:46 PM
spock_rocker's Avatar
memoryFAB.com representative
Default offset question...
im going for 15" wheels this season. but the only size offset is +45 for 15X7" wheel. now will i have camber/rubbing problems? im lowered about 2.5" in the front and 2.3" in the rear. i have 16" now with a +40mm offset and i haven't had a problem with rubbing. any help would be appreciated. thanxx
Old Feb 6, 2004 | 03:08 PM
TeamNextGenChris's Avatar
Default Re: offset question... (spock_rocker)
that offset will tuck the tire even deeper back into the fender than your current +40 offset wheel(i'm assuming they're also 7" wide).i would say if you don't have problems now,you shouldn't with the 15" wheel.
BTW-the wheel has nothing to do with your camber.if you don't change your ride height,the camber will stay the same.
chris
Freshdot
24
Jan 2, 2013 08:04 AM
zamrioo2
Mar 17, 2007 12:01 AM
g2iguy
Dec 27, 2006 10:25 PM
JDM R
Aug 6, 2004 06:04 PM
L4NDO
Mar 30, 2003 03:04 PM
