A few random Accord questions
What's up guys? I have a 92 Prelude with a JDM H22 swap on the way. I plan on swapping my H23 into a 90-93 Accord. I am also planning on using some Prelude parts on the Accord I buy.
With that said....does the Accord have an internal coil in the distributor (based on my searching...it does...just want to confirm)....and if that's the case....can I use the H22 distrbutor from my JDM H22 on the H23 (since I will be using my H23 distributor on the JDM H22)...and have it work properly??
Also, will OEM 97-01 Prelude springs and shocks make the Accord sit a little lower than if it has OEM 90-93 stock suspension??
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">
I have had a 90, 91, and 92 accord ex and as far as I know the 90-91 are internal coil and the 92 is external (mine went out not too long ago x.x)
w/ the suspension ?......im thinking thats a no....im guessing stock h22 powered preludes have stiffer springs in the front (this is the case w/ the Sir Accord in JDM land)......this is to account for the SLIGHTLY heavier H22, and therefore will make the front sit up even higher (assuming ur prelude was an SH).......im doubting the OEM prelude **** will even fit onto the accord.....at least not w/o some minor refabing
