D15bvtec?
Old Feb 6, 2004 | 01:48 PM
egizzle8
Guest
Posts: n/a
Default D15bvtec?
Are the pistons for a d15bvtec and vx the same cause I was told that they are different and if they are different where would I be able to get a set of new pistons for the d15b? Also if I just put the d15b head on a 1.6 block how much of a difference would there be over the 1.5?
Old Feb 6, 2004 | 05:21 PM
BauleyCivic's Avatar
Risky Business
Default Re: D15bvtec? (egizzle6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote">Are the pistons for a d15bvtec and vx the same cause I was told that they are different and if they are different where would I be able to get a set of new pistons for the d15b?</TD></TR></TABLE>
I believe they are the same pistons as the d16z6...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote">Also if I just put the d15b head on a 1.6 block how much of a difference would there be over the 1.5?</TD></TR></TABLE>
Probably not that much, I wouldnt worry about it.
Old Feb 6, 2004 | 05:53 PM
egizzle8
Guest
Posts: n/a
Default Re: D15bvtec? (BauleyCivic)
The d15b's pistons are the same as d16z6? Need to know for sure cause I'm gonna be picking up a d1bvtec block that needs new pistons for $50. Don't wanna find out that there just available in japan or something.
Old Feb 6, 2004 | 06:00 PM
MikeNice's Avatar
Yes. The vx motor is actually 1.5 vtec-e also. So it will all fit. The bore is all the same size on all SOHC motors.
Old Feb 8, 2004 | 03:42 PM
egizzle8
Guest
Posts: n/a
Default Re: D15bvtec? (MikeNice)
I've also heard that the rods are stronger than the vx's and slightly longer but shorter than the z6's but uses the z6 slugs so now I feel better. $200 d15bvtec here I come!
Old Feb 8, 2004 | 04:58 PM
Risky Business
Make sure you dont use VX pistons
Old May 2, 2004 | 08:17 AM
d15bcrex's Avatar
putting a d15b head on a z6 block would make close to 145 horse at the flywheel , the d15b cam is beastly but i think you need to use an adjustable cam gear on the z6 with that cam.
Old May 2, 2004 | 09:44 AM
del_fast's Avatar
same
Old May 2, 2004 | 10:58 AM
trooper0641's Avatar
go with the d16a6 pistons...bump on the compression.
pizzadude
Jul 25, 2006 07:05 AM
dohcdelsol
May 23, 2006 08:49 PM
no_one_
Mar 14, 2005 05:54 PM
Luiyo
May 17, 2004 03:51 PM
cascaritas
14
Mar 26, 2004 07:46 PM
