Will ITR dropfork bushings fit in an Si?
Old Feb 6, 2004 | 08:45 AM
SETI20's Avatar
Default Will ITR dropfork bushings fit in an Si?
I want to upgrade to some stiffer bushings, but Energy doesn't let you order seperate bushings anymore, and I only need to change the dropfork on the LCA.
All my other bushings I have already replaced with energy bushings... and my dropfork bushings REALLY need replacing this week.
I can get my hands on some ITR bushings, wich are stiffer...but I am not sure if those will fit in my Si.
Can anyone help?
Old Feb 6, 2004 | 02:47 PM
SETI20's Avatar
Default Re: Will ITR or GSR dropfork bushings fit in an Si? (SETI20)
ttt
I can't find any resource where I can comapare part no's either.
GSR bushings and ITR are likely the same.
Does anyone have experience with those then?
Old Feb 6, 2004 | 03:00 PM
Doctor CorteZ's Avatar
Default Re: Will ITR dropfork bushings fit in an Si? (SETI20)
what is a "dropfork"
Old Feb 6, 2004 | 03:42 PM
SETI20's Avatar
Default Re: Will ITR dropfork bushings fit in an Si? (Doctor CorteZ)
That's the one.
I was tought that "fork" where the shock sinks in to, is called the "dropfork".
Plz correct me if I err
Old Feb 6, 2004 | 03:48 PM
LCA bushing.
should be in your ES master kit.
Old Feb 6, 2004 | 03:59 PM
SETI20's Avatar
That's the whole problem...
I didn't get the master kit back then. I'm in europe, and it's not always easy to get my hands on parts from overseas.
I have replaced all my bushings over time,....but those 2 need replacing (again).
I'll spare you the BS story.....but those are th eonly 2 I need.
...and I need em fast!
Thus my question...could I replace them wih ITR bushings, because they are better quality (harder) then the OEM crx ones.
Old Feb 6, 2004 | 04:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">Thus my question...could I replace them wih ITR bushings, because they are better quality (harder) then the OEM crx ones.</TD></TR></TABLE>
not sure if the diameter is the same on the ITR's.
xci_ed6's Avatar
I think prothane sells them seperately, and check suspension.com, they list ES parts seperatly.
-Dustin
Old Feb 6, 2004 | 04:15 PM
SETI20's Avatar
I noticed that the part numbers for Integra and CRX are different... so I think I'm screwed.
Old Feb 6, 2004 | 04:28 PM
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">so I think I'm screwed.</TD></TR></TABLE>
just put real bushings in , aka : spherical bearings.
PatrickGSR94
Apr 17, 2009 05:42 AM
Scrappy_jm
Sep 25, 2007 09:33 PM
gsxr
Oct 25, 2002 04:02 AM
ALF
Jun 26, 2002 02:55 PM
Disco Monkey
Oct 16, 2001 07:05 PM
