Exhaust question !!!!
I'm goin to get my 2.5 custom exhaust done tomorrow for my 88 crx si.I wanted know if it would be bad if i run the exhaust underneed of the gas tank?Thanx
Rick
Rick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickcrx »</TD></TR><TR><TD CLASS="quote">I'm goin to get my 2.5 custom exhaust done tomorrow for my 88 crx si.I wanted know if it would be bad if i run the exhaust underneed of the gas tank?Thanx
Rick</TD></TR></TABLE>
Well why would you want to run it under your gas tank? I wouldn't risk it...what if it scrapes?
To make it staight and tip over in the end.I know is wrong but i just wanted know if any body have it done yet.My plans are make 2 90 degrees bends around the gas tank and straight back.
Ummm...I assume it's turbo'd? Why would you do 2.5" on an NA small diplacement motor if it's not FI? I think 2.25" with less bends would be better or even 2" if you need more TQ.
WRX34
WRX34
if you're doin a right side exit exhasust, 2.5" piping might get a lil tight under there w/the rear sway bar.
that's gonna depend on your muffler of choice's lentgh, how much JDM SLANT you want...to scrape on speed bumps etc...
Right now my car is N/A.It will be turbo soon.Im goin to run it tru the driver side and i don't know if i should go over or under the suspension.
Fallen86
10
Jan 7, 2006 02:19 AM
AnToNy
36
Sep 15, 2005 07:44 PM
hondacrxflyer
Welding / Fabrication
Sep 9, 2004 07:22 AM
