Installing front GSR suspension/brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">Which shocks are taller? Thanks
The Integra shocks are taller than the 88-91 Civic/crx ones.....
</TD></TR></TABLE>The Integra shocks are taller than the 88-91 Civic/crx ones.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">So I would be better off using my stock springs and shocks?</TD></TR></TABLE>
Do you just want to keep the car at stock height? What are your plans for it?
I have stock shocks with H&R springs. I would like to keep at least the springs, but if I can, it would be easier to use the whole shocks/spring.
I also have to keep my lower control arms because I have a Jim Fab crossmember and need to keep my radius arms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">I have stock shocks with H&R springs. I would like to keep at least the springs, but if I can, it would be easier to use the whole shocks/spring.
I also have to keep my lower control arms because I have a Jim Fab crossmember and need to keep my radius arms.</TD></TR></TABLE>
Hmmm, I'm a little confused there, you can't just use one or the other, you have to use both shocks and springs. If you want to keep your ride at the same height as the H&R springs lower the car, try getting some adjustable shocks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
To make my question a little more simple (sorry, I haven't slept all night
Can I use the shocks/springs out of my CRX?
</TD></TR></TABLE>To make my question a little more simple (sorry, I haven't slept all night
)Can I use the shocks/springs out of my CRX?
Can I use the shocks/springs out of my CRX?</TD></TR></TABLE>
So you want to use shocks/springs from your crx on your crx?
I'm even more confused.....
)Can I use the shocks/springs out of my CRX?</TD></TR></TABLE>
I believe the question is - Integra Upper Control Arm and Knuckle w/ CRX Lower Control Arm. Can you use those on a CRX with the CRX shock/spring assembly? If not what parts from the front Integra suspension will be needed for a front brake conversion (besides knuckle and caliper)?
Yeah basically wed retain the CRX LCA and then swap on the whole integra brake/spindle/hub thing. But do we need the upper control arm from the GSR or do we need both the A arm and the upper control arm from the GSR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incogNitto »</TD></TR><TR><TD CLASS="quote">I believe the question is - Integra Upper Control Arm and Knuckle w/ CRX Lower Control Arm. Can you use those on a CRX with the CRX shock/spring assembly? If not what parts from the front Integra suspension will be needed for a front brake conversion (besides knuckle and caliper)?</TD></TR></TABLE>
Ahhhh, for front Teg brakes, all you need are the DA knuckles, calipers, rotors, and pads. The rest you keep from your crx, especially the upper arms, keep the stock ones....
Thanks man. This is all coming out of a 95 GSR. Same should apply right?
</TD></TR></TABLE>Thanks man. This is all coming out of a 95 GSR. Same should apply right?
Thanks man. This is all coming out of a 95 GSR. Same should apply right?</TD></TR></TABLE>
No, you cannot use 94-01 Integra knuckles, you can use the calipers, rotors, and pads from a 94-01 but not the knuckles, you're camber will be fuct. Use 90-93 Integra knuckles, or 90-91 EX Civic sedan knuckles....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">Can I use my stock knuckles?</TD></TR></TABLE>
Not for the big brakes.....no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">Bah, so I'd need DA or EG knuckles. You wouldn't happen to have a diagram would you?
No, you cannot use EG knuckles!! Listen to me!!!!
You can <FONT COLOR="red"><FONT SIZE="4">only</FONT></FONT> use 90-93 Integra or 90-91 EX Civic sedan knuckles!
</TD></TR></TABLE>No, you cannot use EG knuckles!! Listen to me!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">Never knew 90-91 sedans had an EX trim.
Thanks for the help
88-89 never had an EX, only 90-91 did, no problem...
Thanks for the help
</TD></TR></TABLE>88-89 never had an EX, only 90-91 did, no problem...
LMAO!!!
</TD></TR></TABLE>LMAO!!!
