REAR WHEEL BEARING REPLACEMENT
Old Feb 6, 2004 | 05:13 AM
jason_alt's Avatar
Default REAR WHEEL BEARING REPLACEMENT
Anyone ever had to replace the rear hub bearing assembly?
Looks pretty straightforward enough. Anything I should know before I do it, like greasing specific areas or being careful when removing certain parts?
Old Feb 6, 2004 | 07:19 AM
89civicdx's Avatar
Default Re: REAR WHEEL BEARING REPLACEMENT (jason_alt)
If you have rear drum brakes theres not much to do alll you have to do is pull off the rear drum , take off the big nut, slide off the hub and slide on the new one.
Might be the easiest job you ever do on your car
Old Feb 6, 2004 | 03:38 PM
Doctor CorteZ's Avatar
drum or disc , still easy as pie.
Old Feb 6, 2004 | 05:20 PM
Tyson's Avatar
the only problem you might run into is the inner race being siezed onto the spindle, which might take some coaxing and leveraging to get it to come out. try to use some penetrant like PB blaster or at worst case get a bearing puller. or, just reuse the inner race if youre really desparate. otherwise yes, easy.
Old Feb 6, 2004 | 06:03 PM
FourthGenHatch's Avatar
I've never done the wheel bearings on my car but I did the front wheel bearings on a 4x4 4Runner. No way a Civic one could ever be as big of a pain in the *** as a 4x4.
Old Feb 7, 2004 | 02:27 AM
Mista Bone's Avatar
D Tranny Guru
5-7 minute job per side.
Old Feb 7, 2004 | 11:18 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (jason_alt)
32mm
Old Nov 21, 2004 | 10:14 AM
crxgator's Avatar
was it easy enough to take off the 32mm nut with the car lifted in the air, or did you take off the dustshield, put the wheel back on and loosen it off while the car was on the ground?
also how did you know you need a new rear wheel bearing? i think i need it done, cause im getting this very loud noise coming from the back, and when i jerk my wheel i can make it the noise softer and louder...
kwae
Honda CR-V & Element
Mar 13, 2016 08:35 PM
eg:R
10
Oct 15, 2011 02:15 PM
DmcL
Nov 8, 2006 09:15 AM
bward
Jul 17, 2006 07:40 AM
Steve91
Aug 26, 2002 02:51 PM
