ITR Rear Bumper Support
Old Feb 5, 2004 | 10:12 PM
RGoose18's Avatar
Default ITR Rear Bumper Support
Mine's trash and I'm going to be installing a new one come spring. Has anyone replaced this on their R. It seems fairly simple and straight-foward, as do many things in life. Any extra parts I'll be needing? Things to look out for? Thanks in advance
Old Feb 6, 2004 | 01:28 AM
Rhetoric's Avatar
Default Re: ITR Rear Bumper Support (RGoose18)
Not many things to look out for in this one. Its torqued down using two bolts, I think theyre 17mm? You can see these two bolts in the rear hatch area, kind of close to your trunk tie bar, but facing up.
If I remember correctly, it is necessary to take off the tail lights and the piece below it (has the itr decal) to remove the bumper to get to the support.
Old Feb 6, 2004 | 08:52 AM
RGoose18's Avatar
Default Re: ITR Rear Bumper Support (Rhetoric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhetoric &raquo;</TD></TR><TR><TD CLASS="quote">Not many things to look out for in this one. Its torqued down using two bolts, I think theyre 17mm? You can see these two bolts in the rear hatch area, kind of close to your trunk tie bar, but facing up.
If I remember correctly, it is necessary to take off the tail lights and the piece below it (has the itr decal) to remove the bumper to get to the support.</TD></TR></TABLE>
I can do it w/o taking the piece w/ the decal off. I try not to **** w/ the sheet metal. Thanks for the reply, seems fairly straight foward
Old Feb 6, 2004 | 09:11 AM
PM-Performance's Avatar
its very straight forward. youll have no probs at all . you dont need to take anything off but the rear bumper cover.
Old Feb 6, 2004 | 03:07 PM
RGoose18's Avatar
Default Re: ITR Rear Bumper Support (itr206)
good chit, thanks
range hadies
Feb 28, 2012 09:25 AM
allmotorlsbaby
Apr 7, 2009 09:07 PM
1SiKSoL
Jul 22, 2007 01:06 PM
ILoveJDM.
Jun 29, 2006 04:47 PM
Vazquez911
Feb 17, 2002 11:08 AM
