HELP,.JDM Steering wheel!
Well I just bought a EK9 JDM MOMO wheel!
Now I'm hearing things like it won't fit in my R??
What should I do cancel it or what!
Search only had 1 topic That Said that & it had 1 reply saying that he didn't think(JDM EK9 Wheel) it works for the DC2R
Damn now I'm pissed,...anyone know how to make it work! It was a good price BTW!???????????????????
edit: Posted this after I bought it found out they may not be enterchangable
for my Dumbass for jumping on a Deal.
Still need help
for my Dumbass for jumping on a Deal.Still need help
Thanx guys! He gave me my money back,..but I am now bidding on one that says:
EG6,DC2 SRS JDM MOMO Steering wheel
now does that mean they are the same between the EG6/DC2 model and just not the EK9? RIght? It has a diffrent hub or something?
Well I hope this one goes through.
thanx again guys!
thanx again guys!
Ok Thanx again! NOW..what is that little yellow harness coming out the back of some of them?? I've seen 1 that shows it and the other has no pic of that little plug
Do I have to have that or no??
I gotta make sure I get the right 1 now!
Make sure you see a pics of the rear hub on the wheel you bitting on.
DC2R wheel have key slot on the spline at 9' and 3' O clock position.
EK9 wheel have key slot on the splind at 12' and 6' O clock position.
So far I had informed 2 ebay seller posting wrong pics of CTR wheel and they corrected their descriptions. That yellow plug will plug directly into our USDM
SRS Cable Reel and a black wire connection from the wheel will plug into the
horn cable.
horn cable.
You guys sure know your CHIT!
So I GOTTA have that Yellow plug?
WEll I'm bidding on 2 right now! 1 shows the yellow plug and the other does not but they are both sittin @ 9' & 3 so they are legit but now I gotta worry about the plug!
(<----tax money ownz me)
ps- EBAY QUESTION---Anyone know how to retract a bid? I need to do that to 1 I've bidded on just cuz it dosen't have that plug!
I'm so anxious to get it I'm not checking on the little things(little kid in a candy store)
Worse case senerio if it dosen't have the Yellow plug I can make it work????
One more thing must do is modify your cable reel by removing the 2 plastic key tips which rotates the key plate the MOMO SRS hub slot seat onto. If u don't, by
just turning the Cable reel to postion the 2 key Pin inorder to insert it into the 2 hole on the momo hub, the hub shaft never seated properly flat. One problem is the wheel hub nut will end up loosen as time goes by and its DANGEROUS. Also your signal return won't work properly of turning off on slight right turn.
I found this out drivng around for half a day after installing it early morning and the center nut started to loosen.
Exit Music
Jan 10, 2006 12:00 PM
