MAINT REGO on cluster what could it mean need help ASAP
Old Feb 5, 2004 | 07:37 PM
EM1_GIL's Avatar
Default MAINT REGO on cluster what could it mean need help ASAP
at first it would come on when i would start the car but today it was on and would not go off
i already seached but i did not come up with anything
PLEASE HELP
i might just be in my head but my gsr has running like **** lately
Old Feb 5, 2004 | 07:39 PM
Kendall's Avatar
That's the Mainenance Required light. Pay it little mind, reset it, or remove it. All it does is indicate, on preset intervals, when the car should be serviced. Give your car a good tune up, it should run better.
Old Feb 5, 2004 | 07:45 PM
EM1_GIL's Avatar
Default Re: (Kendall)
so it's just a reminder to service your car?
if so whoo big relief off my sholders i'll reset the ECU tommorow
i do need a tune up tho
thanks for the help
Old Feb 5, 2004 | 08:01 PM
threatcon13's Avatar
New User
Default Re: (gsRmang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsRmang &raquo;</TD></TR><TR><TD CLASS="quote">so it's just a reminder to service your car?
thanks for the help</TD></TR></TABLE> Theres a little blue button underneath the dash, (drivers side) just hit that and it will turn it off.
Old Feb 5, 2004 | 08:02 PM
Kendall's Avatar
Or you can pull the gauge cluster (takes about three minutes) and just remove the bulb that lights it up.
EM1_GIL's Avatar
Default Re: (Threatcon13)
thanks, so i guess i is suppose to scare me
cause it worked
Old Feb 6, 2004 | 12:46 PM
revhigh89's Avatar
under the panel below the steering wheel, there is a box with a button, just reach ur right hand below, it should be on the right side just behind the fold of the panel, a little switch just push it in ( kinda like a nintendo button) and it will reset, just put ur car on ACC power and press that button, the maintenance light will disappear...
Old Feb 6, 2004 | 10:17 PM
EM1_GIL's Avatar
Default Re: (evilryu530)
thanks guys i almost got worried
hmk2100
May 23, 2006 01:06 PM
oxSLEEPERxo
Nov 29, 2005 08:17 PM
civicEXtreme
Oct 6, 2005 11:32 AM
jdmekrsi
Oct 13, 2004 06:39 AM
