Engine light after installing intake for ep3
Old Feb 5, 2004 | 06:47 PM
Jaypee's Avatar
Default Engine light after installing intake for ep3
I installed AEM short ram intake today and afterwards the engine light came on. I'm guessing it's because the IT is not hooked up, since I have no where to plug it in to. Any suggestions? Or do I have to drive with the engine light on?
JP
Old Feb 5, 2004 | 06:53 PM
GreenBean's Avatar
Default Re: Engine light after installing intake for ep3 (Jaypee)
I am assuming by IT, you mean the intake temperature sensor...the intake should have had a hole for that...and yes you need it.
Old Feb 5, 2004 | 06:54 PM
ITR_1211's Avatar
Default Re: Engine light after installing intake for ep3 (GreenBean)
short ram tube should have a hole for you to put in.
Also make sure to reset your ECU
Old Feb 5, 2004 | 06:56 PM
GreenBean's Avatar
Default Re: Engine light after installing intake for ep3 (Darryl Musashi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darryl Musashi &raquo;</TD></TR><TR><TD CLASS="quote">Also make sure to reset your ECU</TD></TR></TABLE>
I forgot about that part
Do the idle learning procedure also, basically cut everything off and close the doors, no radio, no a.c., no nothing, on and let her idle for like 10-15 minutes...
Then drive it like you stole it
Old Feb 5, 2004 | 07:45 PM
Jaypee's Avatar
I couldn't find anywhere on the tubing to install the IC plug. How do you reset the ECU?
Old Feb 5, 2004 | 07:47 PM
ITR_1211's Avatar
There should be a hole on the intake for the sensor to plug in. Are you sure you got an intake system for the EP3?
To reset your ECU, disconnect your battery (negative) for 10 sec. then reconnect it.
Be sure to also have your radio code handy.
Old Feb 5, 2004 | 07:51 PM
ITR_1211's Avatar
This is an injen intake for a DC5, but it should look something like this:
Old Feb 5, 2004 | 08:06 PM
A L I A S's Avatar
even if you reset the ecu (which you have to do anyways) you still have an intake temp sensor out in the open.......so i say, get another intake or drill a hole for the sensor
thats my $.02
Old Feb 5, 2004 | 08:16 PM
ITR_1211's Avatar
Default Re: (tig ole bistro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tig ole bistro &raquo;</TD></TR><TR><TD CLASS="quote">even if you reset the ecu (which you have to do anyways) you still have an intake temp sensor out in the open.......so i say, get another intake or drill a hole for the sensor
thats my $.02</TD></TR></TABLE>
But he should'nt have to drill. The intake should have a hole in it, assuming it is the correct one for his car.
Old Feb 5, 2004 | 09:15 PM
Jaypee's Avatar
Default Re: (Darryl Musashi)
well the AEM package indicates it's made for 2002-2003 Civic Si. I am missing a rubber grummet that should've come with the package. Does that have anything to do with the Intake Temp. Sensor?
JP
Old Feb 5, 2004 | 09:23 PM
Jaypee's Avatar
Default Re: (Jaypee)
I'll appreciate any kind of description or picture if you have one of where to plug in the ITS plug.
JP
Old Feb 5, 2004 | 11:07 PM
eg_nezay's Avatar
The hole should be about the size of a quarter and just about the middle of the intake.
Also, so you dont erase your radio settings, just take out the 15 ecu fuse for a few minutes.
The fuse box is located in your engine bay by your drivers side headlight.
Since this was the only pic that I had handy, dont mind the circle as it was used for something else.
Just so you get an idea where to look, mine was located at the bottom line of that red circle you see on the pic.
Modified by eg_nezay at 8:20 AM 2/6/2004
Old Feb 6, 2004 | 05:39 AM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaypee &raquo;</TD></TR><TR><TD CLASS="quote">I'll appreciate any kind of description or picture if you have one of where to plug in the ITS plug.
JP</TD></TR></TABLE>
If its not there, call the place where you bought it and call Aem if needed.
Old Feb 6, 2004 | 05:54 AM
Jaypee's Avatar
Default Re: (GreenBean)
Thank you for your replies, I left a message with AEM
JP
Old Feb 6, 2004 | 06:17 AM
blue03ep3si's Avatar
I got an A-Spec SRI and it's directly opposite the little hose(not the crankcase breather hose)...here's a pic ...it's on the right hand side.
Old Feb 6, 2004 | 09:32 AM
Jaypee's Avatar
Default Re: (blue03ep3si)
I found a little hole underneath the intake pipe, but is there suppose to be an adapter of some kind of should I just plug the ITS into the hole?
JP
Old Feb 6, 2004 | 11:49 AM
HaTcH_BmX's Avatar
when i had my AEM CAI i had to cut the rubber piece a little in order to make it fit on the hole for the sensor. so if you think you had the wrong rubber part, just cut it a little bit and make it fit.
Old Feb 6, 2004 | 03:44 PM
Jaypee's Avatar
Default Re: (HaTcH_BmX_Ep3 kid)
the only problem is that it didn't even come with the rubber part. So now I know they missed something. AEM is kinda booboo eh?
JP
Old Feb 6, 2004 | 04:48 PM
eg_nezay's Avatar
Well for the mean time until you get the rubber grummet, use electrical tape and wrap it around the sensor, leaving it the same thickness as the hole in the intake.
NOTE: Make sure you dont leave the tape too far in the intake, you dont want it being sucked up.
Old Feb 6, 2004 | 04:51 PM
jaydub's Avatar
Default Re: (eg_nezay)
or you could run to home depot and spend $.50 on a grommet.
Old Feb 6, 2004 | 07:59 PM
HKS-HIPOWER's Avatar
Default Re: (jaydub)
check the origanal intake tube i think you may use it from there
Old Feb 7, 2004 | 12:50 AM
Jaypee's Avatar
Default Re: (HKS-HIPOWER)
The IAT sensor has two small prongs sticking out of it which I'm guessing must plug into the intake pipe. Even if I plug the sensor into the tube with rubber grommet, will it still work. I'm just trying to get my engine light to go off.
Thanks for the advices, JP
Old Feb 7, 2004 | 05:09 AM
vanbells's Avatar
Find a way to get a grommet for the sensor. I didn't see my grommet when my SRI came in. I ended up finding it underneath all the packing peanuts. My CEL is still on though. It's too hot in the engine bay.
Old Feb 7, 2004 | 09:05 AM
Jaypee's Avatar
Default Re: (vanbells)
how does Grommet look like...pictures would help!
JP
Old Feb 8, 2004 | 12:51 AM
Jaypee's Avatar
so I tried installing my sensor into the intake today and decided there is no freakin' way I can fit my IAT sensor into that little hole. I mean do I have to cut the sensor out of the OEM tube to fit it into the AEM intake or what? Should I just return it? I called and left a message with AEM, but they're not calling me back. Am I better off with another brand? Injen?
JP
