Single layer head gasket...
Old Feb 5, 2004 | 06:22 PM
turbofodo's Avatar
Default Single layer head gasket...
Here's the deal....i found ross pistons at a killer price...81.5mm and it doesnt give the compression ratio of the ls head...so i went to C-SPEED.com and did the conversion....it shows up as 8.8:1 cr...that is too lower than i want... i figured with a single layer headgasket i would be where i want to be(9.2:1)...
now for the question. would a single layer gasket seal well enough with a forced induction setup?
and also... Where do i find a single layer gasket for a b18a1 with an 81.5mm bore
thanks for the input...and by the way i DID search this and came up with nothing...if there is a thread then link me to it..thank you.
Ben
Old Feb 5, 2004 | 06:31 PM
Matty.'s Avatar
Default Re: Single layer head gasket... (turbofodo)
very unforgiving setup. both deck and head need to be surfaced if any warpage present. must ensure that its torqued properly as well
Old Feb 5, 2004 | 06:54 PM
mmuller's Avatar
Mad Scientist
I donno, that's already unreliable for na so with boost even more.
The deck and the head need to be perfectly straight
Old Feb 5, 2004 | 07:05 PM
turbofodo's Avatar
do you think that maybe i should have the head milled and get a two layer? i just want to know how i can get the compression that i want with those pistons
Old Feb 6, 2004 | 01:22 PM
turbofodo's Avatar
anyone?
kevin7200
Dec 23, 2014 04:47 PM
silentdaredevil2
Nov 24, 2005 12:29 PM
Evs-One
Mar 3, 2003 01:09 AM
mini-cRx
Feb 15, 2002 07:15 PM
