what is my compression?
i'm not sure what my compression will be once my motor is finally done being built.
i have a
gsr head
LS block
LS crank
LS Eagle H Beam Rods
stock LS headgasket
the pistons i bought were advertised as JE 9.0:1 84mm
INVDOME DEPTH .120
COMP. DIST 1.181
i have the paper that JE sent with them with all of the specs. but i'm not sure how to calculate exactly what my compression will be with the given information.
can anyone figure that out by what i've listed, or is there anything else that is needed?
i have a
gsr head
LS block
LS crank
stock LS headgasket
INVDOME DEPTH .120
COMP. DIST 1.181
Here u go mang this might be able to help u out a little.
http://www.c-speedracing.com/h...c.php
tegasaurus
Jan 20, 2004 05:43 PM
