Plugs on the back of a b-series block........
Old Feb 5, 2004 | 04:24 PM
whiteblurr's Avatar
Default Plugs on the back of a b-series block........
Here soon I will be installing the prelude oil cooler fittings in my crvtec block to release the excessive crankcase pressures. Does anyone know what size those hex plugs are on the back of the block????
Thanks
Old Feb 5, 2004 | 04:28 PM
Kendall's Avatar
No offense, but what stops you from getting a hex wrench set and finding out, or a Helms manual?
Old Feb 5, 2004 | 04:36 PM
whiteblurr's Avatar
Default Re: (Kendall)
I have yet to find hex heads that large...... it's close to a 19-20mm hex head from the looks of it
Old Feb 5, 2004 | 04:42 PM
whiteblurr's Avatar
Default Re: (whiteblurr)
NM, I just went and looked closer.... they aren't that large!
Old Feb 5, 2004 | 05:13 PM
Sliced Beard's Avatar
they should be a 17 or 19 millimeter
also if you are removing the plugs that require an allen key
they use a 14mm allen key
Old Feb 5, 2004 | 06:10 PM
whiteblurr's Avatar
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">also if you are removing the plugs that require an allen key
they use a 14mm allen key</TD></TR></TABLE>
You are my hero
Old Feb 5, 2004 | 06:31 PM
RenoRacing's Avatar
and what I did since i didn't have a big huge allen that size was to tripple nut a 14mm bolt and stick it's head in there and break that tight sucker loose. (same as the double nut method but this one required three) and a big breaker bar as well!
GSRcivicSon
May 16, 2016 06:30 PM
vanny_david
Jul 14, 2009 03:25 PM
THEUSED
Apr 19, 2005 03:10 AM
acy76
Mar 23, 2004 07:36 PM
