clutch not relasing after replacing trans
Old Feb 5, 2004 | 03:43 PM
psilberschatz's Avatar
Default clutch not relasing after replacing trans
I replaced the trans in my 89 si, and put in a new exedy oem replacement clutch at th same time. I got the trans bolted in this afternoon and hooked up the clutch cable only to find that the pedal is super light. It feels like the throwout bearing is not even comming up agains the pressure plate. I put in the TO bearing onto the trnas a few weeks ago, and I know its in there, but is there any chance that it could have gone in backwards? Is there anything i can do with the trans in to troubleshoot or do I have to bite the bullet and drop the trans again? Any ideas as to what might be the problem? The new trans I bought used and was supposed to be from a 90si and looks the same as the one that came out. Thanks
Old Feb 5, 2004 | 04:49 PM
unltdacc12's Avatar
Default Re: clutch not relasing after replacing trans (psilberschatz)
Have you tried adjusting the cable? i had the same problem with the same clutch. after adjusting the cable it worked fine. hth
Old Feb 5, 2004 | 04:51 PM
silverCRXTC's Avatar
Default Re: clutch not relasing after replacing trans (unltdacc12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unltdacc12 &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried adjusting the cable? i had the same problem with the same clutch. after adjusting the cable it worked fine. hth</TD></TR></TABLE>
I had the same problem/solution thing after i did a trans swap
Old Feb 5, 2004 | 05:15 PM
cable is fine... I can pull the linkage on the trans all the way to the stop with my hand.
Old Feb 5, 2004 | 05:16 PM
phatrick2332's Avatar
did you torque the pressure plate to the correct specs..think its 10ftlbs?
Old Feb 5, 2004 | 05:20 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
If adjusting the cable doesn't fix it, you have to drop the tranny to see what happend. A bunch of things could be causing it, the only way to find out is to open it.
Old Feb 7, 2004 | 07:28 PM
SoLowCRX's Avatar
$100 says its the throw out bearing. I just went throught this with a ZC swap. The center of the clutch disc was different from the origonal, and the throw out bearing was being stopped from going all the way out. Gotta take it apart again. Let me know!
HypL
Transmission & Drivetrain
Jul 14, 2015 08:10 AM
HypL
Jul 13, 2015 09:44 AM
innes887
Apr 14, 2007 03:03 PM
