Which Intake manifold to use on a b series?
Which one's would you guys prefer? There's quite a few out there but im just gonna name some of the more popular ones like skunk2, JG, AEBS, rev-hard? Which one of these would you guys say will make the most hp mid-to-high end?
It depends, which head do you have? For a P72, the only real upgrade is the Skunk2, but for a PR3, then I'd have to recommend getting the AEBS. I'm not exactly sure about upgrades for LS heads as I've not ever worked with any.
the rev hard one looks pretty good and can be used with either the gsr head or the b16/type r head....and you can use either IAC sensors...on the skunk2 and type r one's..they only allow one kind of IAC sensor to fit...
it depends on your setup...if your running turbo, you will gain more power around 6-8k rpm but if you going all motor you will lose hp...if all motor your better off with stock im.
has anyone seen any gains with the ones that are sold on ebay
they look like the aebs ones
sorry to steal your thread but this question popped into my head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPERNATURAL »</TD></TR><TR><TD CLASS="quote">a ported type r manifold works great also....</TD></TR></TABLE>
wouldnt a ported skunk2 manifold work great ported in a sense too since the 2 manifolds are so much identical to each other?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slixxracing »</TD></TR><TR><TD CLASS="quote">
wouldnt a ported skunk2 manifold work great ported in a sense too since the 2 manifolds are so much identical to each other?</TD></TR></TABLE>
The skunk mani is basically just a worked over type r mani, so in turn, if you want a worked typr r mani, get a skunk 2 one!
claytonsmith
11
Nov 14, 2006 08:29 PM
AnthraxVX
Feb 28, 2006 10:40 PM
JDubya
Dec 8, 2003 04:20 PM
