zc twin cam or sohc vtec u be the judge
alright guys i have a friend of mine that is gonna go either twin cam zc or sohc vtec
they are both around 130 hp to the motor
the question is which would be the better choice.
it will be a daily driver and he will occasionally drag it and maybe do a lil bit of circuit racing on track days.
will the sohc vtec fall into the EF Si chassis or will he need mounts ?
i can also get his ecu chipped if he goes sohc vtec for cheap
what do u guys think will be the better choice and why u think this way.
please don't say b , h or even k - series as he doesn't have that much money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNDER PRESSURE »</TD></TR><TR><TD CLASS="quote">It basically comes down to prefferance. I would go with the D16Z6
exactly...i would go ZC...
</TD></TR></TABLE>exactly...i would go ZC...
as far as your tech questions, the z6 and the zc will both bolt up in his engine bay. it does come down to his choice, the zc is older but it would be easier to wire, the z6 is newer and although it drops right in you would have to either covert to obd1 or run a modified obd0 e.i distributor fitment, vtec wiring, thermo sensor relocation...
i got the z6
i got the z6
I would go with the Z6 since it is a less outdated motor, but so are both of them. I'd think about investing the money into the stock motor before I'd think about doing a swap to another d-series.
I have the Z6 in my 89 Si. I love its decent power and availability of aftermarket parts. But if you ask some in here they would say neither and go with mildly built A6 for the same money considering he has an Si already but unless he has an HF he is gonna have to convert to MPFI anyhow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yebabee »</TD></TR><TR><TD CLASS="quote">I have the Z6 in my 89 Si. I love its decent power and availability of aftermarket parts. But if you ask some in here they would say neither and go with mildly built A6 for the same money considering he has an Si already but unless he has an HF he is gonna have to convert to MPFI anyhow.</TD></TR></TABLE>
very good point
id say talk to exospeed here on ht and get urself a set of cams and some headwork done and your prolly above and beyond a stock z6 or zc right there.......... if the si motor needs a rebuild then pick up a nice piston/rod combo and u would have urself a purty quick a6...........
very good point
hmm... well my gut is to say the ZC.. becuase my bro had it in his 4-door ef, and i had a z6 in my crx with all the same mods... and his felt more powerfull when i drove his then mine. felt better on the low and mid. but i would probably say the z6 because of the aftermarket support. also when u go to honda for something u can tell them exactly wut u need, unlike with the ZC you'd have to guess and wouldnt really know. my bro learned the hard way (wrong sized bearings on a rebuild and it seized). but thats just my 0.02. good luck choosing
I use to be zc very good motor just drop in and go but watch out if you start going big cams and what not mines was an every day driver with head work big cams cam gears throttle body and ecu only down fall it used to eat distributors for lunch . fastest it ran on slicks was 13.7 so if you can deal with the distrib problems it would be worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloorex »</TD></TR><TR><TD CLASS="quote">
very good point
id say talk to exospeed here on ht and get urself a set of cams and some headwork done and your prolly above and beyond a stock z6 or zc right there.......... if the si motor needs a rebuild then pick up a nice piston/rod combo and u would have urself a purty quick a6...........</TD></TR></TABLE>
Is that a subliminal message or somethin?
very good point
Dimensions are the same bore and stroke
The Design from the DOHC ZC(1984ish) is 7 yrs older than Z6 (1991ish)
That's not to say that the DOHC is crap because it's not
For all D series, from what BISI said, the DX/Si non vtec head 88-91 flows best
The DOHC ZC has the strongest rods and pistons biggest valvse and from what TheOldOne says has the largest ports
The SOHC VTEC had variable intake timing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Gotta Question »</TD></TR><TR><TD CLASS="quote">
Is that a subliminal message or somethin?</TD></TR></TABLE>
lol........ i dunno......... did it work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloorex »</TD></TR><TR><TD CLASS="quote">get urself a set of cams</TD></TR></TABLE>
Yeah, now I want 2 cams instead of just one, but I like my VTEC, damn now I wanna K-series
lol......... thats jumpin a lil much for me......... i will however be sittin in a b16b powered ek hatch within a week
......... big plans for this destroked c5
</TD></TR></TABLE>lol......... thats jumpin a lil much for me......... i will however be sittin in a b16b powered ek hatch within a week
